Digital BW, The Print
request for advice on preparing 1280 w. UT2 inks for shipment
2006-11-12 by jimcongleton
My 1280 has been acting peculiar recently:  the red maintenance light will sometimes come
on when I try to do a nozzle check and I get the "general printer error, check for foreign
objects, etc." message, which could (until now) be cleared by restarting the printer one or
more times. Today it began making loud (really loud) grinding and banging noises. The feed
mechanism in the back also spins periodically. The red (maintenance) light comes on and
stays on.
I'll call Epson on Monday, but obviously I'll need to ship the printer to a service center.
(Unfortunately I'm a few months past the one-year warrenty period.)
My question is this:  presumably I'll need to remove the ink carts, but I know that if I do only
that the inks (UT2) left in the heads will dry up and form serious clogs.  How should I flush
the heads before shipping? I have some empty carts on hand; should I put some Windex in
the carts and try to run a purge pattern? If Windex is the right approach, should I use the
version of Windex with ammonia or without?
Thanks for your help in advance.
Jim C
