flushing liquid
2006-04-24 by bjornaagedk
I want to use my Epson 7000 for Piezo K6 inks. I have a set of empty 110ml carts which I will use as flushing carts. Can I fill them with distilled water or what do you recommend? B
2006-04-24 by john dean
What I always do is use the jrano flush fluid from Media Street. I see here that you can save by buying it in bulk and filling your empty carts. I didn't realize that before. That way you could fill any carts with it. They also make prefilled carts for the 7000 which is what I used. I left it in the machine for a couple of weeks after doing an initial fill. When I put the K6 inks in and did an initial fill with them. I got perfect nozzles then and have had perfect nozzles from then on. I belive you are going to love these K6 inks. If you want beautiful smooth rich output with NO clogging, this is my recommendation. John http://www.mediastreet.com/site/cleaning_fluid.html --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bjornaagedk" <reklamefoto@...> wrote:
> > I want to use my Epson 7000 for Piezo K6 inks. > > I have a set of empty 110ml carts which I will use as flushing carts. > > Can I fill them with distilled water or what do you recommend? > > > B >
2006-04-24 by Greg
This is what I use: http://www.getinkexpress.com/catalog/gie820_cleaner- diluent_for_pigment_inks_4416727.htm Yahoo will probably slaughter the link. Similar to the Jrano but seems to work a little better. If you want prefilled carts, then http://www.weink.com or http://www.inkjetcolorsolutions.com and http://www.inksupply.com has them.
Hello John, Thank you. I read some of your posts regarding K6 in Epson 7000. Do you think I CAN use destilled water? or do Inkjetmall have the sameproduct? Which paper gives a slightly warm tone, something between neutral and Piezotone inks? Bjorn --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean" <deanwork2003@...> wrote:
> > What I always do is use the jrano flush fluid from Media Street. I see > here that you can save by buying it in bulk and filling your empty > carts. I didn't realize that before. That way you could fill any carts > with it. They also make prefilled carts for the 7000 which is what I > used. I left it in the machine for a couple of weeks after doing an > initial fill. When I put the K6 inks in and did an initial fill with > them. I got perfect nozzles then and have had perfect nozzles from > then on. I belive you are going to love these K6 inks. If you want > beautiful smooth rich output with NO clogging, this is my recommendation. > > John > > > > http://www.mediastreet.com/site/cleaning_fluid.html > > > > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bjornaagedk" > <reklamefoto@> wrote: > > > > I want to use my Epson 7000 for Piezo K6 inks. > > > > I have a set of empty 110ml carts which I will use as flushing carts. > > > > Can I fill them with distilled water or what do you recommend? > > > > > > B > > >
Since I haven't used distilled water to attempt to flush out a system I won't comment on that. It seems risky to me but I guess it is possible. I wouldn't do it. I hate working on these machines and the price of flush carts is very cheap in comparison. I belive MIS associates also sells a flush fluid but inkjetmall sells the media street version. Greg just listed another one he uses. As to color I haven't found one that I would call a warm result with these inks though Jon Cone suggests Innova Cold Press. I like that paper a lot but it has a substantial texture that some like and some don't. It resembles Arches Coldpress printmaking paper. Hahnemuhle William Turner is a tad warmer than others but not much. Cone also recommends one of the Bradford papers I believe. Look on their site. I have't tried them yet. I do know that for a cool tone Premier Art Hotpress works well ( Epson Ultrasmooth). John --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bjornaagedk" <reklamefoto@...> wrote: > > > > > Hello John, > > Thank you. I read some of your posts regarding K6 in Epson 7000. > Do you think I CAN use destilled water? or do Inkjetmall have the sameproduct? > Which paper gives a slightly warm tone, something between neutral and Piezotone inks? > > Bjorn > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean" <deanwork2003@> > wrote: > > > > What I always do is use the jrano flush fluid from Media Street. I see > > here that you can save by buying it in bulk and filling your empty > > carts. I didn't realize that before. That way you could fill any carts > > with it. They also make prefilled carts for the 7000 which is what I > > used. I left it in the machine for a couple of weeks after doing an > > initial fill. When I put the K6 inks in and did an initial fill with > > them. I got perfect nozzles then and have had perfect nozzles from > > then on. I belive you are going to love these K6 inks. If you want > > beautiful smooth rich output with NO clogging, this is my recommendation. > > > > John > > > > > > > > http://www.mediastreet.com/site/cleaning_fluid.html > > > > > > > > > > > > > > > > > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bjornaagedk" > > <reklamefoto@> wrote: > > > > > > I want to use my Epson 7000 for Piezo K6 inks. > > > > > > I have a set of empty 110ml carts which I will use as flushing carts.
> > > > > > Can I fill them with distilled water or what do you recommend? > > > > > > > > > B > > > > > >
2006-04-24 by Paul Roark
> Since I haven't used distilled water to attempt to flush out a system > I won't comment on that. It seems risky to me but I guess it is > possible. I wouldn't do it. I hate working on these machines and the > price of flush carts is very cheap in comparison. > > I belive MIS associates also sells a flush fluid but inkjetmall sells > the media street version. Greg just listed another one he uses. > I don't know the exact formulas for the flushing fluids, but I'm quite sure they are mostly water. Additionally, however, something like glycerol is in the formula as a dispersant and humicant. (When used as a pigment ink base, this also raises viscosity and specific gravity.) A small amount of wetting agent is also in most of them. Then there are probably anti bacterial and fungus additives. Bottom line, it might be easier and safer to just buy bulk cleaning/flushing fluid, rinse the empty carts with distilled water, and load the flushing fluid. That is what I do. Paul www.PaulRoark.com
2006-04-24 by sinar001
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bjornaagedk" <reklamefoto@...> wrote: > > I want to use my Epson 7000 for Piezo K6 inks. > > I have a set of empty 110ml carts which I will use as flushing carts. > > Can I fill them with distilled water or what do you recommend? > > > B There are flushing fluids, and then there are cleaning fluids. I would flush with a cleaning fluid and then follow up with distilled water. If you leave cleaning fluid in too long, it might cause some damage because of the strong ammonia products in them. John Nollendorfs
2006-04-24 by James Irelan
I have flushed with distilled water only, and it worked fine, and I have also flushed with distilled water and had a fatal problem with one of the nozzles (all others worked fine). What the etiology of the problem was, I don't know. One thing about using anything that you self fill with is: if you have a problem, did you inadvertently introduce a little piece of crap that wound up clogging a nozzle? Doesn't help you to print if you know that you didn't, but it does help you to not kick yourself for the poor economy of saving on prefilled flushing carts in favor of putting a new head in. James
2006-04-24 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sinar001" <jnolly@...> wrote: > > > There are flushing fluids, and then there are cleaning fluids. > > I would flush with a cleaning fluid and then follow up with distilled water. > > If you leave cleaning fluid in too long, it might cause some damage because of the strong > ammonia products in them. > Please note: The cleaning fluid I suggested from get ink express is NOT compatible with Lexan plastics!!!!!Cracked every one of my cool Nalgene Lexan bottles last time I used it. There is also an extra strong fluid gie800 but I don't suggest it for flushing out a printer as it is REALLY strong. Lots of ammonia in that one!
2006-04-25 by Clayton Price
Some of you may not agree with this, but I've been using the original Windex for cleaning heads for years. At times I've diluted it by 50%, and other times used it straight. I don't know of a single flush cartridge that doesn't use an ammonia based fluid. There is no thickening agent in any I've heard of or seen, and would not suggest using one that does. Ammonia solution is created by dissolving NH3 (ammonia gas) in water - it combines readily. Except for the color, and perhaps some other minor chemicals, that's what Windex is! I've used it on Epson 800, 3000, 1200, 2- 1160's, and the 2200. I'm not suggesting that you use it, but it works for me. Flushing with water won't work as well, especially with pigment based inks, or if there's a difficult clog. Not a bad idea to follow with distilled water. Clay
>> >> I would flush with a cleaning fluid and then follow up with > distilled water. > > Please note: The cleaning fluid I suggested from get ink express is > NOT compatible with Lexan plastics!!!!!Cracked every one of my cool > Nalgene Lexan bottles last time I used it. There is also an extra > strong fluid gie800 but I don't suggest it for flushing out a printer > as it is REALLY strong. Lots of ammonia in that one!
2006-04-26 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Clayton Price <clay@...> wrote: > > Some of you may not agree with this, but I've been using the original > Windex for cleaning heads > for years. Yes I too use Windex, but not when I'm pulling it through thr heads by the ink pump. It tends to foam a lot as it comes out of the heads and makes a mess. I have switched to using a generic brand from Walmart in the half gallon or gallon jugs. Good for manually cleaning out the lines and bottles of my 9500. I then follow up with the other more expensive cleaning fluid. For stubborn clogs the extra strong gie800 (Image Specialists WJ800) really does the job completely and fast! Though I wouldn't recommend using it for flushing the system, the discharge of ammonia when it hit the waste tank would probably knock you off your feet!
