Digital BW, The Print
Two Embarassing Questions
2006-03-24 by G Guhan Gunaratnam
Hello,
I've got some VFA to print on, and I need to know which is the printable
side.  One is cleaner than the other (smoother texture) and whiter.  This is
the side I assumed I should print on.  The first print is coming through the
printer now and I can see some runnning of the ink along the edge of the
print.  I did use -5 for ink density..should I have used more?
What size do you print your final prints when printing on 13x19 paper?
Assuming a 3:2 uncropped image, could anyone share what print size is
considered the standard and what the TOP and LEFT margins should be (for
optical centering)?
Any help is appreciated
Guhan
Re: Two Embarassing Questions
2006-03-24 by edrudolpho
Guhan, this is a link to a method for optical centering.
http://www.russellcottrell.com/photo/centering.htm
As for size, on 13x19 i print anywhere from 12x8 to approx 15.75x10.5
i try to use some fraction of the native 2880 resolution of my 2200 printer.  i.e., 360 dpi,
576 dpi, 720 dpi.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, G Guhan Gunaratnam
<guruguhan@...> wrote:
> Hello,
> optical centering)?
> Guhan
2006-03-25 by gguhangunaratnam
Thanks a lot, that's a nice little formula.
Now my question is, should I use it?  Or should I centre on my inkjet
prints, and use the formula when matting the print?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "edrudolpho"
> 576 dpi, 720 dpi.
> <guruguhan@> wrote:
> > Hello,
be (for
> > optical centering)?
> > Guhan
2006-03-25 by AdventureCam Photo
Don't touch your tongue to the paper!  Simply touch your index finger and
your thumb to your tongue, then touch a corner of the paper.  The print side
will stick to either your thumb or index finger.
Michael J. Pach
AdventureCam Photo
719-260-6637
mike@...
www.adventurecamphoto.com
AOL IM: mikep1967
Thanks Tina,
I think I'll skip the tongue test. I'm pretty sure I've got the it
printing on the proper side, just want to make sure its the brighter
side I should be printing on.
Thanks again
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.2.5/284 - Release Date: 3/17/2006
