This is probably too basic a response but I find that if you do not
select the right version of a sheet in the page set up it can do
this. For example, if you are used to running several printers from a
computer or on a network and you are used to selecting, say, A4, if
you select A4 on the 7600 it will think it is expecting roll paper. I
often forget to go to the sub menu and select "A4 sheet". If I make
this mistake it can sometimes be difficult setting things right again
without a lot of faff. Sorry if this is an insultingly obvious
suggestion, it isn't meant to be. I am just trying to think what
could be causing the problem.
Drew
On 23 Mar 2006, at 20:22, James Irelan wrote:
> I can't get the Epson driver to see my 7600 as being set for sheets.
> It's set on the front of the printer, and nothing is checked in the
> Roll option menu, but it still thinks that it's set for rolls. Any
> ideas?
