Re: Epson Velvet Fine Art greyed out in Epson driver
2006-03-22 by G Guhan Gunaratnam
Thanks Tina, When I choose any of the three manual feeds I can use these media types now. Does that mean Clayton and all others manually feed the paper (I would have done this for final prints since I wouldn't have paper sitting in the printer, but for EEM, my proof paper, I'd like to be able to have some sitting in the automatic feeder. In this situation, I'm using the VFA media type, but actually printing on EEM (as Clayton describes is best/a good starting point). I also noticed that the printable area is much smaller when feeding from the front (when I chose manaul front feed the image which was previously printable unclipped, required clipping with the feeding method). Why is that? Thanks again Tina On 3/21/06 7:05 PM, "DigitalBlackandWhiteThePrint@yahoogroups.com" <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Message: 8 > Date: Tue, 21 Mar 2006 16:55:11 -0500 > From: Tina Manley <images@...> > Subject: Re: Digest Number 3820 > > At 04:26 PM 3/21/2006, you wrote: >> Thanks Clayton, >> >> Regarding the paper, I do have the MK ink installed, I don't know why these >> papers are not available, any other ideas? > > You need to check the paper source. It should be "Manual" for those > papers. I just did the same thing and discovered it by accident. > > Good luck! > > Tina > > Tina Manley, ASMP > http://www.tinamanley.com > > [Non-text portions of this message have been removed]
