Digital BW, The Print
MIS PK ink replacement?
2006-03-15 by sagaface
Is there an MIS PK ink for the 2200 that is the equivelent of the PK for the 2400? I really
would like to try BO on my 2200 with Silver Rag but was informed that the older PK for this
printer would cause more bronzing/gloss differential than the new formula.
Can anyone advise me here?
thank you,
Sarah
RE: [Digital BW] MIS PK ink replacement?
2006-03-16 by Paul Roark
> I really would like to try BO on my 2200 with Silver Rag
> the new formula.
I suspect the bronzing difference is more a function of whether the older PK
used the older base.  All of the MIS inks should be using the new base.  The
base that was started to be used a year ago made a major difference in the
level of bronzing.  You can tell what base is used by smelling the ink.  The
new ink base has what I'd call is distinct ammonia smell.
The 2400 PK is a lighter load ink than the older PK.  With the newer
printers, we've found that lighter loads actually produce a better dmax with
less, if any, gloss differential.
Paul
www.PaulRoark.com
Re: [Digital BW] MIS PK ink replacement?
2006-03-16 by sagaface
-With the newer printers, we've found that lighter loads actually produce a better dmax
with less, if any, gloss differential.-
But that won't be the case with the 2200? will the PK for that be a heavier load ink or will
the MIS formulas be the same for both?
Thanks, Paul...I'm just a bit confused!
Sarah
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...>
> > the new formula.
> Paul
> www.PaulRoark.com
I assume the 2200 PK is the heavier load still.  I have not tested the 2400
v. 7600 PKs in the 2200.  So, I don't know which one would be best.
Paul
www.PaulRoark.com
> -----Original Message-----
> From: DigitalBlackandWhiteThePrint@yahoogroups.com
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> sagaface
> Sent: Thursday, March 16, 2006 9:21 AM
> To: DigitalBlackandWhiteThePrint@yahoogroups.com
> Subject: Re: [Digital BW] MIS PK ink replacement?
> a better dmax
> Sarah
> <paul.roark@...>
> > > the new formula.
> older PK
> The
> the
> The
> with
> > Paul
> > www.PaulRoark.com
> Please visit the Group Homepage to check the Files, and other resources as
> they are often being updated.
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> If you wish to receive no emails or just a daily digest, or you wish to
> unsubscribe, please edit your Membership preferences by visiting this same
> page.
> Please follow these basic guidelines:
> - As threads develop, trim off excess portions of earlier messages to keep
> them short.
> - Good manners are required at all time. No personal attacks or flames.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> - Keep your posts and threads related to the group topic of digital B&W
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
