Hello Siobhan,
>As I now finally have high speed internet I am having a web-site
>created And need to prepare images for it. I am hoping that some-one
>could give me some guidelines on the best way to do this.
I use PS-CS and can share my method. I would never claim it to be the
best, but it works fine for me. I use a workflow that has good
WYSIWYG, so when I'm done working up an image for printing, the
resulting screen image is also what I want to put on my web site. So
the following steps are meant to keep the image visually as is.
1) flatten all layers, discard all alpha channels, saved selections,
attached memos, etc. Get rid of all excess baggage.
2) change to 8 bit (all work is done at 16 bit).
3) insert copyright notice.
4) convert image profile to gray gamma 2.2 (I do most work in Dot Gain
18 or 20%, but browsers display with GG2.2 so my images would look too
dark if I didn't do this - so you may or may not need to do this step).
5) resize to desired image size in a single step using Bicubic Sharper.
6) save as a .jpg with desired filename (my work files are .tif).
That's it. I hope this is helpful.
Clayton
