Re: Sponge or spongeless carts for the 2200
2006-01-14 by Clayton Price
Hi Paul - Could you elaborate on priming the half sponge cartridge and what your modification to what looks like a syringe with a notch cut in the end of the 7 mm length? Are these the refill carts sold by MIS? I'm just starting to print with K7 Piezo cartridges on a 2200, and know I'm going to need to refill carts because of the costs of new ones! BTW, you're accumulating a wonderful body of work - I just visited your website. Thanks, Clay Price On Jan 14, 2006, Paul Roark wrote: >> Alternately how reliable are the 2200 carts with the sponge in one >> half? > > I've been using the MIS versions of those with success for some time. > I use > the version that fits the C86, R220, and R2400. Once I started > priming the > carts before using them the "clogging" issue completely disappeared. > (It > appears to have been an air bubble just above the outlet.) I've > modified an > MIS bottom file adapter for this purpose that works much better than > their > standard ones. See http://home1.gte.net/res09aij/Mod_Bot_Fill.jpg > > I try not to let the sponge get dry between the reservoir and the > sponge > half. I also rinse the outlet when I swap carts -- which I do a lot. > So > far, so good. > [Non-text portions of this message have been removed]
