Digital BW, The Print
Epson K3- 4800 – How to get the best B&W print?
2006-01-13 by bradytao
I was directed to this group from a posting I did at
largeformatphotography.info's forum.  Glad to have found you folks!
I have recently purchased the Epson 4800 printer for use primarily
to print fine art B&W images.
Given: All of my work is shot in 2 ¼ or 4x5 negative, then scanned
at 8,000 lines on my Howtek 8000 line drum scanner. I then take the
scanned file into CS2 and drop the res to a working res of 4,000
lines for the 4x5 images and leave it at 8,000 lines for 2 ¼. The 8K
file is then archived.
After CS2 clean up and any burn/dodge is done to the working file, I
then drop the 4K working resolution to 720 dpi from printing on the
4800. My CS2 settings are with Red River profiles loaded, printer
output is set to Black Point Compensation –On, Premium Photo Glossy
paper, 2880 DPI, High Speed Off. The set up is for CS2 to manage the
printer.
I've been partial to glossy paper as it has a similar look to the
Oriental Seagul that I used to use when printing with an enlarger,
but I have been told that I should be working on matt papers if I
expect to get into any gallaries, which is my goal! Paper I'm
currently printing on is the Red River UltraPro Gloss.
I have no problem dedicating my 4800 to strictly B&W work, if that
will produce a better print.
My Mission: Exchanging of printing set up techniques with other
users of the Epson 4800 doing B&W fine art work.
I would like to hear what others with the Epson 4800 have found to
be their optimum techniques used to generate the best looking print.
To my knowledge, nobody is making a set of B&W inks for the 4800
that would go beyond what the defaults inks are from Epson.
Any suggestions on refining my printing technique would be
appreciated. Thanks, Jack
Re: [Digital BW] Epson K3- 4800 – How to get the best B&W print?
2006-01-13 by Steve Kale
If you have a 4800 use Epson Adv B&W.  As designed by Epson it is a
non-colour managed workflow (No Color Management in the CS2 print menu).
Make your greyscale workspace Gray Gamma 2.2.  Leave the Epson driver at
default settings for now then explore the tint picker.  There are a bunch of
papers worth trying (I'm not sure I believe the comment that it has to be
matte).  Explore your own preferences.  Epson Premium Semigloss or SemiMatte
are great "glossy" papers.  The new Crane Museo Silver Rag sounds like it's
worth exploring also.  For the matte papers there's a whole bunch.
Hahnemuhle Photorag 308 is a stalwart but listen in here for others.  I'd
explore and get to know your 4800 before changing ink setups.  You should
take a look at QTR Create ICC for profiling Epson Adv B&W setups (and other
B&W workflows) and closing the no colour management gap that I referred to
above.
> From: bradytao <stereoholic@...>
> Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> Date: Fri, 13 Jan 2006 15:55:25 -0000
> Subject: [Digital BW] Epson K3- 4800 – How to get the best B&W print?
> Given: All of my work is shot in 2 1Ž4 or 4x5 negative, then scanned
> lines for the 4x5 images and leave it at 8,000 lines for 2 1Ž4. The 8K
> output is set to Black Point Compensation ­On, Premium Photo Glossy
> printer.
