Helen;
You're right, I for one haven't been paying attention, sorry.
Interesting that we wound up at essentially the same place but for
different reasons-this is essentially the arrangement I'm using in
my R1800, with the exception of the R toner-I have LLK in that spot,
because that channel bands less than the C or M. Also, I'm using the
MIS K4 and R1800 inks instead. I found when I switched over the K
inks that MIS' version was warmer and required more neutralising,
but OTOH a carbon print is very pleasantly warm. I agree that the
blue and Cyan make for a better neutral toner-it takes less added
color, and the results are very pleasing. And the combination
produces a really wonderful cold tone which used on the right image
practically makes me shiver. Dark foggy mornings never looked so
ominous before...
Steve Karafyllakis
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "helen_bach2003"
<helenbach@h...> wrote:
I most liked the
> warmth of the red toner and the coolth of the blue toner - probably
> because magenta and cyan casts are reminiscent of bad inkjet B&W.
> Though my own work does not suit anything other than fairly plain
> printing, I like to have options for the people I print for.
> So that's how I came to LC, R and B as the colour inks. The Krystal
> Topkote is my latest experiment.
> Best,
> Helen
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joshhackney"
> <joshhackney@g...> wrote:
> > Helen,
> > Thanks for your post. I assume you are using QTR, or another
RIP.
> Could you explain
> > how/why you arrived at your decision to use K3/LC, R800/blue, and
> R800/red? I'm
> > curious why you went with the blue and red rather than LM. I
assume
> Krystal Topkote is a
> > gloss optimizer.
> > Thanks!
> > Josh
> > Message: 20
> > Date: Thu, 12 Jan 2006 17:19:31 -0000
> > From: "helen_bach2003" <helenbach@h...>
> > Subject: Re: Crane Museo Silver Rag/beta testing
> > John,
> > At least someone is paying attention. I've mentioned this a few
times
> > in the past, with little response. I use K3 inks in a 2200: MK,
> > K3/PK, K3/LK, K3/LLK, K3/LC, R800/blue, and swap between
R800/red and
> > Krystal Topkote. I get the MK and the K3 inks from 110 ml carts.
> > It works for me.
> > Best,
> > Helen
