Digital BW, The Print
Greg - spectrophotometer vs colorimeter
2006-01-11 by wgh2005
Greg - I completely agree that something like a GMB software-hardware
package would be ideal - but my work flow would not justify the several
thousand dollar expense. In my case, the two profiles I've made using
PrintFixPLUS (not the PRO version, yet) are every bit as good as the two
profiles I've just received from cathysprofiles.com. Cathy Stratton uses
the latest version of the GMB software and hardware.
If I were a really high-volume professional, or if I were in the business
of making profiles for other people, I would find a way to buy GMB. Other
than that, it seems to me that my options are to buy each profile from a
custom profiling service, or to make my own in some way. So far, by far the
easiest and most accurate way I've found to do that is PrintFix - either
the PLUS or the PRO version. My first two profiles took about 20 minutes
each - that's total time, including  printing the reference image
and  making prints of three of my own images, then making adjustments to
achieve a perfect match between print and calibrated monitor. As you
predicted, the profiles weren't absolutely perfect "right out of the box" -
but they were surprisingly close. After printing out the test image
supplied, and then printing out three different images of my own which have
proved to be especially difficult to print, I wound up making a single
adjustment, subtracting a small amount of yellow. Every other factor -
brightness, contrast, saturation, and the colors other than yellow, were
all spot on.
I'll try the PRO version of PFP for a while. If I don't seem to be getting
perfect matches easily, I'll consider your advice about a true
spectrophotometer - or, fo course, continue to buy profiles from Cathy.
Bill Hansen
