Digital BW, The Print
Can one spot R2400 EPSG prints?
2005-12-11 by Scott Jones
Greetings,
I was printing away today and noticed that an image I have worked up
from very small size to about 11x14, has now shown a bright white spot
in some foliage off to one side. I didn't see this in the smaller
prints. I checked the original scanned negative file and lo and behold
it was there. Perhaps a scanning artifact or dust that I had missed in
my spotting run on the file. I have since fixed it in the master file,
but my question is this:
I would like to save this print instead of reprinting it. I there a way
to spot this area to a middle gray? In the darkroom world, I would have
been able to easily do this with spotone. This particular spot would
have taken me several dabs with a fine brush.
I am specifically printing with R2400, ABW, K3 inks on Epson Premium
Semigloss paper.
Any advice???
Re: Can one spot R2400 EPSG prints?
2005-12-12 by scott_now_coming
Sakura makes archival ink pens in various tip sizes and a variety of
colors. I have black ones, but I'm sure there are gray markers
avalible. There are other brands of pigment markers, also.
I bought mine  at my local Michael's Store.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones"
<peanutdogs@h...> wrote:
> Greetings,
up
spot
behold
in
file,
way
have
would
Premium
> Semigloss paper.
> Any advice???
2005-12-12 by Scott Jones
Thanks for the advice so far. With trepidation I actually tried some
Spotone on a print with a white "spot" and to my surprise it actually
worked fairly well. Not quite as smooth as with silver gelatin, but
still quite a passable "save" for a print with a white defect. It did
not screw up the surface like I thought it would.
Any other solutions out there?
Scott
2005-12-12 by Greg
> Scott
http://forums.dpreview.com/forums/read.asp?forum=1003&message=16179461
Scott
2005-12-12 by jt
Scott,
Back in June there was a post on this subject from Roger Sopher, who
said:
'An easy way to spot digital prints (matte ones at least) is to print a
step wedge on glossy paper using the same inkset, curves etc. as the
print to be spotted. Even when the ink drys it can be easily lifted
with a moistened camel hair brush. The technique is virtually the same
as with Spotone except glossy paper is used to hold the different
densities of gray-black rather than a ceramic dish. The step wedge
makes matching the densities pretty straight forward.'
I have not had reason to use it yet, but it seems to offer an ideal
solution.
Regards,  John T
actually
did
> Scott
2005-12-13 by steveh0607
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones" <peanutdogs@h...>
wrote:
>try the spot healing brush or clone stamp tool in photoshop. zoom in close and work
slowly and methodically and it should work.
> Greetings,
> Semigloss paper.
> Any advice???
