QTR 2.30 icc - Help!
2005-07-16 by hkbenji
Hi all, I hope that someone might be able to help me... For BW, I use a hp 7960 printer with the grey cartridge. I'm very interested in creating icc profiles for that printer, so Roy's new stand-alone application seems to be perfect for that. I'm just having a few problems getting it right. OK, so first - printing the QTR-21 gray target; should I use the embedded 2.2Gamma profile or discard it and print as a untagged gray file? Then, using Photoshops print with preview - I should set it up as "No Color Management", yes? Next, scanning of the target, appears to be working fine. Then, linearizing - I'm a bit lost here; I assume this requires the use of the actual QTR program? I've never used QTR before, so I'll have to do some reading up on that one. Assuming I've got the linearization done, and got the icc-file; do I use that on a grayscale or RGB file? If grayscale, what Gamma? Can I use it to Soft-Proof? If so, do I use the Perceptual Rendering Intent or something else? How about in the Print with Preview Setup - Perceptual or Relative Col.? Many Thanks for your help! Ben
