Digital BW, The Print
R800 and BW
R800 and BW
2005-05-07 by andrew
Since I've seen the odd question about the Epson R800 and R1800, I thought I'd briefly
detail my own experience with the R800.
I own both a 2100 and R800. For those who don't know, the R800 dispenses with the inks
that are the biggest contributors to metamerism: the light cyan, light magenta. It also has
no light black. It has instead red and blue, plus the gloss optimiser. For colour work, this
means prints with greater gamut, far less colour shifting under different lights, but
compared to the 2100, less subtlety and without that gorgeous luminous quality on Semi-
Gloss.
With the 2100 I went through the whole learning process of magenta-toned and rainbow-
hued grayscale images. I finally had made a set of custom ICC profiles by an academic and
artist who's research interests include printing with Epson UltraChrome. He made a set of
profiles, balanced for a mix of daylight and incandescent light. However, on Epson Semi-
Gloss there were still observable colour shifts.
At that point I began to investigate QTR and now use that for the bulk of grayscale work
on the 2100. My wife and I run a part-time wedding and portrait business and probably 1/
3 of the prints we sell are grayscale, much of that because our clients love the look of the
QTR warm tones.
As an aside, I should note that on Archival Matte at least, one can obtain pretty neutral
grayscale output through the print driver by having custom profiles made (and
subsequently printing) using the Photo Realistic option instead of No Colour Management.
Apparently it reduces the gamut, bad for colour work, but beneficial for grayscale
neutrality.
With the R800 things were quite different. The supplied Epson ICC profiles yielded
grayscale prints that had a rich, dark chocolate tone, different from the warm/sepia QTR
output. It was quite pleasing to the eye. I then had made some custom profiles for colour
work as the skin tones weren't always so good using the Epson ones.  Well, for the first
time ever I had what looked to me to be dead-neutral grayscale on Semi-Gloss and
Premium Glossy paper. They don't colour shift either. On Premium Glossy they really do
look quite similar to darkroom prints, minus the hairs, dust spots, imperfect centring, etc.
That's the good news. The bad news is this: on just a handful of colour prints that have
fine hair or fur (my daughter, a horse), the (Windows) print driver smears and fuzzes up
the hair. It's really awful, looks like shocking compression or sharpening artefacts, except
that the 2100 will render the same image perfectly. And it is the driver, not the profiles.
Now, I haven't yet tested those same images in grayscale, but the possibility of the
problem occurring gives me less confidence to rely on the R800; I need to check every
print very carefully. It also doesn't give me the confidence to buy an R1800.
Apologies for the ramble.
Re: R800 and BW
2005-05-07 by Clayton Jones
Andrew,
Thanks, it was a good ramble.  I think you added some worthwhile
information, as there have been lots of questions about these
printers. I learned a lot from it.
Clayton
