Saving unsharp masking as a layer
2005-05-06 by yaakovsinclair
Is there a way to save usm as a layer, so that you can save different degrees of sharpening depending on your print size? thanks!
2005-05-06 by Mark Savoia
You can save each degree of sharpening (per print size) as a separate action and then just run it when needed. Name each action according to size for example. Mark On May 6, 2005, at 7:31 AM, yaakovsinclair wrote: > Is there a way to save usm as a layer, so that you can save different > degrees of sharpening depending on your print size? > thanks! [Non-text portions of this message have been removed]
2005-05-06 by Louis Dina
For me, sharpening is usually the last step before printing. In Photoshop, I will usually create a new top layer (Ctrl-Alt-Shift-N), then stamp that layer with a composite of all underlying layers (Ctrl- Alt-Shift-E). I will add sharpening to this layer (usually a little stronger than desired), then use the opacity slider to tone down the sharpening to the desired final amount. If I leave this in PSD or layered TIF mode, I can adjust it for any desired printing mode. All underneath layers are left untouched, so I can always delete the sharpening layer without damaging the original. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "yaakovsinclair" <sinclair@a...> wrote:
2005-05-06 by Jim Farrell
There is a way of unsharp masking using layers courtesy of Russell Brown, basically create a duplicate of the background layer, apply unsharp mask (over do it somewhat), duplicate this layer. We now have two unsharp mask layers. Using the blending modes, change the topmost layer to a blending of lighten, and the other unsharp mask layer to darken. Now using the opacity slider adjust the layers opacity until you get the correct amount of sharpening (you will probably have a lower value on the lighten layer). If necessary you can apply a layer mask and then paint using the paintbrush in the mask to further refine the areas that you wish to be sharpened. As a matter of interest this method can apply to most filters (eg blur). Hope this helps Jim _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of yaakovsinclair Sent: 06 May 2005 12:32 To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Saving unsharp masking as a layer Is there a way to save usm as a layer, so that you can save different degrees of sharpening depending on your print size? thanks! Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ * To unsubscribe from this group, send an email to: DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns ubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed]
