Digital BW, The Print
need help with qtr, get banding accross all printed images
2005-03-20 by mehrdad
hi all,  i am using a 1280 with the u2 inkset and i can print fine
either directly printing to the printer or applying curves and then
printing, it all looks fine. when i print using qtr, i get banding
across the entire image. the effect  looks like to be 4mm in width and
a different shade of what i am printing.
i am using a 1280 with u2 inkset and the yellow position loaded with
glop. and printing using the following curves in
ut2-EpermLuster-netral-3 @ 100.
resolution: 1440: super
speed faster
dither algorithm: ordered
  regards, mehrdad
Re: need help with qtr, get banding accross all printed images
2005-03-20 by Nick H. Nugent
This sounds so familiar. I had a similar problem in an earlier version
of QTR on Windows XP, but no such problem in the latest 2.2a version.
I didn't try to find a solution as I didn't need QTR at the time.
I'm not sure what the problem is though. You might want to do a
complete uninstall and reinstall of QTR, especially rename your old
QuadtoneRIP directory before reinstall.
--nick
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, mehrdad
> speed faster
>   regards, mehrdad
2005-03-20 by john dean
Reduce your output speed in regard to increasing  the resolution setting. My
QTR output is flawless but you can't print fast, now way. It is very slow. I have
a friend who experienced this same situation with Studio Print at faster
speeds. It just didn't work.
John
