Digital BW, The Print
Densitometer Question
2005-03-11 by zonepeter
My densitometer arrived today without calibration plaques.  I have a
Kodak Q60 (IT8) reflection target.  I was able to locate a web site
with densities for the gray scale on the bottom, including averages
for the d max and d min from 16 different charts they had tested.
I used these values and calibrated the densitometer.  Based on this,
I am getting readings that seem reasonable.  (EEM 1.64 dmax and HPR
at 1.72)
Is this a fairly accurate way to go or should I bite the bullet and
buy the calibration plaque.  I will be using the densitometer to
build curves with QTR or IJC/OPM.
Peter
Re: [Digital BW] Densitometer Question
2005-03-11 by Ernst Dinkla
>at 1.72)
>Thanks,
>Peter
Maybe it is wiser to find several good pieces of black and white
ceramic. Take them with you to some local (offset) printshops and check
whether they are  below or above their tiles in measurements with their
densitometer. It will tell you which are good and the limitation of your
or their meter on Dmax. To check the linearity of the densitometer you
better get a true B&W paper based step wedge. You could check it with
the printshops densitometers too and it is less likely to fade in time.
The IT8 ones are color paper and they fade in hue and density, average
numbers from the web are a risk too, an IT8 target should have a batch
measurement table somewhere, check the number and date on the target and
do a search. If it isn't too old you will find the numbers somewhere, if
not consider the target as being too old.
Ernst
Re: Densitometer Question
2005-03-11 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
average
batch
and
somewhere, if
...aside from the possibility of fading,a paper target's accuracy will
deteriorate due to handling and normal use, including the necessary
direct contact that's made with the densitometer--so  such a standard
is not likely to be relaible for long-term use (i.e., used for
frequent recalibration). If the densitometer was advertised as "with
plaque" but did not include it, I'd certainly complain to the seller
and demand some compensation.
Phil
2005-03-12 by zonepeter
Thanks Ernst and Phil.  Sounds like the best bet is to buy the plaque.
The plaques weren't advertised with the densitometer, but it was a
good enough deal to make it worth it anyway.  Thanks again.
Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Phil Rose"
> average
> batch
target
> and
> somewhere, if
will
standard
> Phil
2005-03-12 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "zonepeter" <zonepeter@a...> wrote:
> at 1.72)
Is your densitometer an X-rite?
My X-rite 414 (status A) needs a cal plaque with a d-max around 1.8. An X-rite status A cal plaque only has white, black, and gray spots. The black is 1.8. If you try to cal it with something around 1.6, it actually decides it's a status E, status I, or status T instrument (I am not making this up) and the firmware goes into status E/I/T mode. Cal then demands you meter the magenta, cyan, and yellow spots of the plaque for a status E/I/T instrument. And the ned result is a really messed up, non-linear instrument.
It took hours on the phone with x-rite tech support to get this resolved.
