Re: [Digital BW] 2200 and Entrada question
2005-03-09 by Alan.Huntley@cox.net
John, I use Entrada 300 all the time using the rear paper feed slot on the Epson 2200. Just follow the directions as outlined in the manual... Here's what I do: 1. Push lever to its lowest position; paper light will blink as you said. 2. Lift lid and position front edge of paper so it's about 1/4" beyond the small gray rollers. Make sure paper is straight, too. 3. Raise lever up one notch. 4. Close lid and hit paper feed button. 5. Print. Hope this helps. Alan Huntley
> > From: "Mr_Misty_44" <jharvey@...> > Date: 2005/03/09 Wed AM 10:51:57 EST > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] 2200 and Entrada question > > > > This is just a short one. For those who are using Entrada 300g paper > or other 300g paper with the 2200. Where do you set the paper lever. > For paper or envelope. What is the heaviest paper used and if paper > is OK for 300g what is the point at which one should switch to > Envelope setting. And, by the way what is the third mark under > neath the envelope setting which causes the paper light to blink? > Thanks as always, > John H
