Re: [Digital BW] Digest Number 2903
2005-03-01 by Bart Nadeau
I sure would welcome a Photoshop plug in version. I am scanning a very large collection of old images from 1900 - 1940 on both glass plates and film, sizes ranging from 120 to 8 x10, condition ranging from wonderful to terrible. Such a plug on would sure cut down the retouching. Bart On Mar 1, 2005, at 7:54 AM, DigitalBlackandWhiteThePrint@yahoogroups.com wrote:
> In DigitalBlackandWhiteThePrint@yahoogroups.com, "dealy663" > <dealy663@h...> > wrote: >> >> Hi everyone, I've been a lurker in this group for a while, but haven't >> posted much. >> >> I'm looking for some opinions on a dust and scratch removal program >> for scanned black and white film. I haven't been able to find anything >> that was really helpful in this regard, and got to thinking about >> creating something myself. >> >> In some ways what I'm planning on developing would be similar to the >> Polaroid Dust removal program, but would make use of more >> sophisticated image analyis techniques. By this I mean, it would take >> into consideration the amount of film grain present (via the speed of >> the film and allowing the user to specify a level of "graininess"). >> The size of of the film grain with respect to the size of the actual >> image on the negative would also figure into the dust/scratch >> selection algorithms. >> >> This program would not be smart enough for you to set a couple of >> options and then presto you'd have something as clean as a Digital ICE >> repaired piece of color film (That seems unlikely for now). But would >> offer significantly less work than going through your file with the >> clone-stamp tool or the healing brush at 100% pixel resolution in >> Photoshop as I've usually done with my B/W scans. This whole process >> started after I spent about 2 hours cleaning up a scan of a 35mm Tri-X >> neg with the PS CS healing brush. By manually applying some of these >> techniques I was able to clean a similarly dirty neg in about 15 >> minutes. I expect that I can build a PS CS plugin to do this >> relatively simple stuff without too much trouble. But the really cool >> benifit will arise if my ideas regarding automated dust and scratch >> identification pan out. >> >> This probably wouldn't be of need to those who only have to clean up 5 >> or 6 defects per image. I'm talking about really messed up negs with >> over 100 defects per image! >> >> So here are my questions: >> >> 1. Would such a program would be of interest to you B/W scanning >> types? >> >> 2. If so would most of you be interested in a standalone application, >> or a Photoshop plugin that would work with 16-bit files? If I were to >> build a standalone program I would only code it to work with TIFF >> files. >> >> 3. What percentage of those interested are on Macs vs PCs? >> >> Thanks, Derek
