Digital BW, The Print
QTR 2200 Density & Contrast
2005-02-16 by krn_ptr
I have pulled my first tests with QTR on the Epson 2200 and they are
wonderfully neutral.  They are, however, a little light and don't match the
monitor tonality or the density of the same (greenish) image printed with the
Epson driver.  I'm printing on Velvet Fine Art and I've used both the EEM and
PFA profiles with little or no difference in density.  I dropped a contrasty curve
layer on the image in CS to see if the paper could actually print at a higher
density and it did.
Is there a simple way of increasing the density and contrast in QTR?  There are
"Expert" setting options in the QTR driver, but I don't know when or how to
access them.  I'd like to know if it's possible to achieve simple(?) density and
contrast adjustments before getting into what looks like a serious learning
curve to produce profiles for Epson and non-Epson inks.
peter
Re: QTR 2200 Density & Contrast
2005-02-16 by Marco Ristuccia
Have you converted your images to "QTR Gray Matte" profile before
printing? If not give it a try!
You can find the QTR gray profiles at the following address (file
grayspace.zip):
http://homepage.mac.com/royharrington/FileSharing2.html
Bye
Marco
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "krn_ptr"
are
match the
printed with the
the EEM and
contrasty curve
at a higher
> density and it did.
QTR?  There are
or how to
(?) density and
learning
> Thanks,
> peter
2005-02-17 by krn_ptr
No, I haven't.  I'm just switching mode to grayscale.  I'll give it a try, Marco.
Thanks.
But is there a way to make small adjustments in the driver?
peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Marco Ristuccia" <
> grayspace.zip):
> Bye
> Marco
> are
> match the
> printed with the
> the EEM and
> contrasty curve
> at a higher
> > density and it did.
> QTR?  There are
> or how to
> (?) density and
> learning
> > Thanks,
> > peter
