Digital BW, The Print
Help with Roark's curves
2005-02-03 by guy_staley
I'm just not getting it. I am printing with a E2200 using UT7 inks on a Mac. At
this point, I have MIS PK in the K slot, and MIS LC in the yellow position.
When I print using no curves(i.e. - 16 bit grayscale file; printer space "same as
source"), the prints essentially match what I'm seeing on screen; not bad, in
fact pretty sweet. However, when I try to use Paul's curves(switching first to
48bit RGB, creating a new curves layer and then loading the appropriate
curve, and finally printing), the prints emerge looking extremely low in contrast
as if the black jets aren't firing. I was getting the same results with Eboni Black
as well. I MUST be doing something wrong, although I have read through
Paul's workflow several times, and can't seem to discover where I'm getting
lost.
Honestly, aside form the usual suspects (bronzing, wheel tracks, micro-
banding), the prints I'm getting without Paul's curves are pretty good (albeit a
tad warm do to the PK inks). But I would love to have the control over print
tones that the UT7 inkset is capable of.
Any help will be mucho appreciated!
TIA,
Guy Staley
RE: [Digital BW] Help with Roark's curves
2005-02-04 by Paul Roark
Guy,
>... E2200 using UT7 inks on a Mac... MIS PK in the K slot,
>printer space "same as source"), the prints essentially match
>what I'm seeing on screen; not bad, in fact pretty sweet.
>48bit RGB,
48 bit may be overkill.  24 bit works fine.
The layer must be the top one.
The dmax ought to be the same whether curves are used or not.
Be sure the driver "Color Management" section is set to "No Color
Adjustment."
I'm not sure what else to suggest.
Paul
www.PaulRoark.com
Re: [Digital BW] Help with Roark's curves
2005-02-04 by guy_staley
Hi Paul,
Thanks for your reply.
The missing bit of info was: "Be sure the driver "Color Management" section is
set to 'No Color Adjustment'..." - Somehow, I missed that and actually
transposed your instructions for printing with the sliders(where you specifically
write "Color Management: Color Controls checked, Mode = Standard") into
your instructions for printing with the curves. Upon re-reading, I now see that
you specify "No Color Management" for use with the curves.
The curves now print properly.
Thanks so much!
-Guy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <
paul.roark@v...> wrote:
> Guy,
> >48bit RGB,
> Adjustment."
> Paul
> www.PaulRoark.com
