Digital BW, The Print
UT2 probs
UT2 probs
2005-01-15 by tgos3
Hi --
This my first post to the group.  I have spent a fair bit of time
looking through previous posts and 'files', as well as relevant QTR
and UT2 website files, help files, etc.
I have done B&W gelatin-silver printing for about 40 years, using
Zone system for the last 20 or so.  I used to use Ilfobrome,
Gallerie, Seagull, and Dektol.  Now I use a Windows XP Pro, a 1280
with Epson inks, profiled in PhotoCal 2.6 for color, unprofiled for
G2.2 sisngle black printing, and a Spyder monitor profile on a CRT
monitor.  Have been almost happy with single tone Epson black, except
for the nasty dither pattern in the high values.  Tried the
ImagePrint RIP demo, but still had metamerism,(faint magenta)
although the dither is much less obtrusive.  Don't want to spend the
bucks for an obsolescent printer with dongle and still have
metamerism.
Sprang for UT2 inks, which i used up (well, there's a bunch of Eboni
left over) in a day of experimenting and printing.  When viewing the
21 patch file, from 90% to 50% seems pretty compressed, as do the
patches on a printout. I only have a transmission densitometer, so I
couldn't measure them.  My UT2 prints certainly do not have the
contrast in the shadows that i could achieve with single black, or
with ImagePrint.  Reducing the ink limit and gamma in QTRgui didn't
really solve the problem, since the blacks got weaker without the
shadow contrast problem being solved.
I tried Epson HW Matte, Archival Matte, and Arches Hot press
watercolor.  I tried setting paper type (and presumably ink deposit)
to Photo Paper, Matte Heavyweight, and Photo Quality Glossy Film
(which was the best).  I tried printing both with QTR and using
Paul's curves in Photoshop.  (eventually had to reinstall my 1280
driver due to software nastiness/printer hang)  I played a bit with
Gama setting using the Epson driver to print at 1.8 or 2.2.  I tried
carbon, neutral, and cool curves in photoshop.
For some images Carbon looks nice, but still the low densities are
pretty muddy and flat looking by my standards, using UT2 inks, when
the gray mode print looks good on the screen, and has printed fine
using other ink/apps.  I was able to make new files that printed
better, by making the print look 'too light' in G2.2 mode on the
screen, before RGB/curves were applied.
I tried making a PS Working Space custom file to change the gray
scale image on screen, but even with 'preview' checked i can not get
the image to update on the screen in real time.  PS seems to be set
up to have reflection density values entered numerically, although i
can move the curve.
Before i order any more MIS inks, i am interested to know whether
people have had to change their images to adapt to UT2 inks, as one
would, say, to a new paper/developer combination, or have they been
able, using stock Ruark curves, to get 'good' prints, matching the
G2.2 monitor image of the unmanipulated files that have printed well
in the past.
At this point i am tempted to wait for the new Epson printer
announced in Japan, which supposedly prints tritone blacks.
Basically I want a good Dmax and invisible dither in the lightest
tones below paper white.  I think the stock Epson black ink looks ok,
although the UT2 colors are ok with me too.
So far UT2 'caliberation' has been more expensive and time consuming
than it would have been for wet printing with a new combination ;-)
Kinda frustrating that at this point in digital printing we still
don't have a conveniently achievable WYSIWYG method to print high
quality B&W.  I am perfectly willing to believe this is entirely due
to user error and inexperience on my part, since so many others seem
to be happy with their results.  I'd love to hear what I am doing
wrong.
Ted
Re: UT2 probs
2005-01-15 by Johnny Eades
Hello Ted,
How do you set up your soft proofing? That's the only way to get
WYSIWYG. Roy Harrington has posted in one of his messages a LAB
Grayscale work space, and that is what I use for both the work space
and proofing space. My print and monitor images match, allowing for
dry down to be just a tad lighter than when it comes off the printer.
Try this and see if it works. Make sure your monitor is calibrated. I
use Gray Gamma 1.8 and 5000K to allow me a longer tonal range in the
lower Zones and viewing under an Ott-Lite.
Your friend in Photography,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "tgos3"
<egosfield@c...> wrote:
> Hi --
except
> metamerism.
Eboni
I
deposit)
tried
get
i
> can move the curve.
well
> in the past.
ok,
consuming
due
seem
> wrong.
> Ted
Re: UT2 probs
2005-01-15 by tgos3
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
space > and proofing space.
thanks -- I'll check it out again.  I have not been using monitor
proofing, since the monitor image of the workspace was predictably
accurate when i was doing single black with Epson ink.  I tried to
set one up using the instructions at Roy's site, but i could not get
the monitor image to change until after i saved the curve, which
meant more interations than i had patience for -- i guess i will just
have to trudge to successs....
I have been using 5000K and 2.2, with daylite fluorescents, since 2.2
is the 'standard' windows monitor gamma, and it works well for my
color printing work.  I have sometimes used 1.8 when i print at
2800dpi.
thanks again,
ted
RE: [Digital BW] UT2 probs
2005-01-15 by Paul Roark
Ted,
For matching the monitor to the print, see
http://home1.gte.net/res09aij/Monitor-Profiling.htm .  It describes a way to
make a custom profile for the monitor.
The density aim points to which the grayscale curves are matched is,
essentially, the Lab scale, but with the middle of the scale set to the
point "half way" (in Lab visual terms) between good matte dmax and paper
white.  The steps should appear as equal steps.  However, it is not the
typical curve that is used for color inksets.
You may be having trouble with more than just this issue.
See my information on UT2 if you haven't yet.  You may spot a setting or
workflow problem.  See http://home1.gte.net/res09aij/UT2-Readme.htm
I'll send you some files off list that may also help.
Paul
www.PaulRoark.com
Re: [Digital BW] UT2 probs
2005-01-15 by tgos3
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@v...> wrote:
> Ted,
a way to
that's the method i tried, which will produce a custom workspace
curve, but will not do it in realtime -- i can only see it after i
have saved it and used it as proof space.  technically doable, but
kinda tedious -- but of course life is short and art is long.
the point "half way" (in Lab visual terms) between good matte dmax
and paper white.  The steps should appear as equal steps.  However,
it is not the typical curve that is used for color inksets.
it looked different, like a real long toe, to me, but i guess it
depends on what one is used to.
have done, thanks
you did, thanks, and by now you have my purge file scans
I think i have two problems:  how much ink to put on the paper, while
still getting a good Dmax, and what kind of contrast curve to use at
the low end.  That means 1)what kind of paper type setting will give
me the best ink density,and 2) do i need to make a 'Clayton
type' 'back end dot gain curve' to get the low end contrast right.
So far i have gone through a whole UT2 color cart and about 10 sheets
of 8x10 paper trying to get calibrated, and i suppose if i am willing
to do that again i might get it nailed down. I have also managed to
make some decent prints of some images along the way, by changing the
original files for better low end contrast, but haven't worked out a
consistent method yet, if there is one.
I haven't been clever enough to cut 8x10s into quarters, but i soon
will be ;-)
ted
Re: UT2 probs
2005-01-15 by jimpegoda
I'm having some of the same problems with UT2 inks that Ted is
having although my 21step.tif file looks fine on my monitor, which
has been calibrated with a ColorVision Spyder and PhotoCAL.
Regardless of the state of the monitor the 21step.tif file should
print with even separation.
I recently purchased a 1280 and UT2 inks for black and white
printing. I tried black only printing with my 2200 and liked
everything except the coarse dot pattern. QTR did a great job of
making my 2200 print black and white without color casts or
metamerism but I thought the dots were still too visible in the
lighter values. I had high hopes for the UT2 inkset but after years
of creating very accurate color prints I am currently very unhappy
with the black and white results I'm getting using UT2.
After 3 days of testing here are my findings.
Like Ted, I found the contrast very lacking in the middle and darker
values. Printing the 21step.tif file confirms this. I have printed
the 21step.tif file using Roark's curves, the Epson Driver (slider
method) and QTR. The results are consistent with a little variation.
Generally the steps between 60% and 85% show very little separation,
the steps from 0% to 5% are too large and the three steps from 90%
to 100% are too large. The values between 70% and 85% show almost no
separation. I noticed that neutral prints had slightly better
separation the carbon prints so I printed cool and sepia versions
and found that the cool version of the 21step.tif file printed with
much better separation and the sepia version had very uneven value
separation with a large jump between 60% and 70%. I printed the
21step.tif file on my 2200 using Epson UC inks and QTR and got great
separation across the value range. Images I've printed using the
three methods mentioned above are all lacking in contrast and
exhibit some posterization, which is very noticeable in skin tones.
I can't help think that there may be a problem with the UT2 inks.
Maybe a bad batch? I hope somebody can prove me wrong because I just
invested a lot of time and money into this system.
Jim
> Hi --
QTR
for
except
> metamerism.
Eboni
I
didn't
deposit)
with
tried
when
get
set
i
> can move the curve.
one
been
well
> in the past.
ok,
consuming
due
seem
> wrong.
> Ted
RE: [Digital BW] Re: UT2 probs
I'll see if MIS will send me one of their UT2 carts to see what I get with
my 1280.  Ted's inks looked OK, but ...
Usually settings or profiles tagged to the files are the problems.
Paul
www.PaulRoark.com
_________________________________
Sent: Saturday, January 15, 2005 2:00 AM
Subject: [Digital BW] Re: UT2 probs
Jim
> Hi --
QTR
for
except
> metamerism.
Eboni
I
didn't
deposit)
with
tried
when
get
set
i
> can move the curve.
one
been
well
> in the past.
ok,
consuming
due
seem
> wrong.
> Ted
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
PAUL: Printer Question (WAS:[Digital BW] Re: UT2 probs)
2005-01-15 by scott_now_coming
PAul,
Is the Epson 10,000 seies suitable for b&w printing.
They print considerably faster that the other Epson wide-format
printers.
But I did notice the droplet size is 25% larger (5pl vs. 4pl)
Thanks Paul,
Scott
get with
> Paul
> www.PaulRoark.com
> -----Original Message-----
> From: jimpegoda [mailto:pegoda@c...]
darker
variation.
separation,
no
great
just
> Jim
> > Hi --
> QTR
1280
> for
CRT
> except
> the
> > metamerism.
> Eboni
> the
so
> I
or
> didn't
> deposit)
> with
> tried
are
> when
fine
> get
> set
although
> i
> > can move the curve.
> one
> been
> well
> > in the past.
> ok,
> consuming
> due
> seem
> > wrong.
> > Ted
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
RE: PAUL: Printer Question (WAS:[Digital BW] Re: UT2 probs)
Scott,
I'm sure the 10,000 (or the pigment version of that series if they are
different) would be able to do B&W, but whether an existing inkset would be
appropriate is another question.  The increased dot size might make the UT7
"light" inks not quite light enough.  If that was the case, one might want a
light gray ink in the Y position instead of the sepia, for example.
The lack of a LK (I think that is the case with the 10000 series) doesn't
make much difference to B&W printing with the Epson driver.  If this turns
out to be a good place for the Glop in a RIP-controlled printer, then that
might be missed for glossy printing.
So, there are some open questions, and the printer might not have the
flexibility of the current UC printers.
Hope this helps.
Paul
www.PaulRoark.com
From: scott_now_coming [mailto:scott_now_coming@...]
Sent: Saturday, January 15, 2005 9:58 AM
Subject: PAUL: Printer Question (WAS:[Digital BW] Re: UT2 probs)
PAul,
printers.
Thanks Paul,
Scott
get with
> Paul
> www.PaulRoark.com
darker
variation.
separation,
no
great
just
> Jim
> > Hi --
> QTR
1280
> for
CRT
> except
> the
> > metamerism.
> Eboni
> the
so
> I
or
> didn't
> deposit)
> with
> tried
are
> when
fine
> get
> set
although
> i
> > can move the curve.
> one
> been
> well
> > in the past.
> ok,
> consuming
> due
> seem
> > wrong.
> > Ted
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
page.
them short.
the membership.
Yahoo! Groups Links
Re: UT2 probs
2005-01-15 by tgos3
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jimpegoda"
Using Dot Gain 30% makes my (profiled like yours) monitor better
match my printed 21 step tablet.
separation,
no
> separation.
similar to my experience
exactly my experience, and cool actually looks neutral
while neutral looks v. slightly warm to me
i don't get posterization, but i do get rasterization of the dither
in the highest values using QTR/Gui/8bit tiffs, which is not apparent
in 16 bit versions printed with PS color management and Roark curves.
Head alignment has been checked and verified.
Using the 'purge' file Paul kindly sent me, i printed files which
showed some of the inks a bit darker and browner than his scans of
his own output, but they didn't seem tremendously off value to either
of us.
I still can't find a paper value that reliably prints Eboni dark
enough as grayscale/single black, and the dither pattern is too
obtrusive for me to persist.  I have double printed to get good
densities in the shadows when single black printing.
Aside from issues of permanence, Eboni as single black is no better
than Epson for me, but i might keep trying with UT2 if i can lick the
bad low value contrast.
Using Dot Gain 30% on monitor, RGB/Roark EEM neutral, heavyweight
matte paper, printer set at heavyweight matte paper, No Color
Management, and Best Photo (presumably 1440, since the latest 1280
driver does not (!!?) specify numerical choices -- boo hiss) I can
get a print that matches the screen reasonably well.
It still has too low contrast in the lowest values (around 70% down)
and looks kind of dull.  I may have goosed the 'Zone ii-iii' values
too much trying to increase the dark contrast, but it was the best i
could do.
Still haven't made a custom visual workspace, or tried 'Color
Controls' with a print space that differs from the source space.
ted
Re: UT2 probs
2005-01-16 by jimpegoda
Thank you Ted and Paul for you feedback. Would it be possible to
email me that purge pattern scan so I can check it against mine. I
realize the colors may not be perfect because of monitor differences.
either
> of us.
I've had good BO printing results with my 2200 at 2880dpi and the UC
matte black ink on EEM and Velvet Fine Art Paper. The 2200's dither
pattern is less visible than the 1280's and the black is a bit
warmer. The dither pattern is still too visible for me though.
down) and looks kind of dull.  I may have goosed the 'Zone ii-iii'
values too much trying to increase the dark contrast, but it was the
best i could do. Still haven't made a custom visual workspace, or
tried 'Color Controls' with a print space that differs from the
source space.
I've been printing using QTR, Epson Driver Sliders and Paul's Curves
and although each method's output varies the significant lack of
dark contrast is apparent in each. For years I've had great results
making color prints with the 1280 and 2200 using PS color management
and soft proofing...can't wait to get this UT2 thing figured out.
Wish you the best of luck Ted on your Digital B&W adventure
Jim
Re: PAUL: Printer Question (WAS:[Digital BW] Re: UT2 probs)
2005-01-24 by Ernst Dinkla
Paul Roark wrote:
> Scott,
The 10000CF droplet size is close to the 9600 droplet size and
both printers have variable droplet sizes. I don't think you
have to be afraid that the highlights show the dot size with
any quad inkset, the BO with 8 pass printing of the 10000 is
already quite acceptable.
The 9000 and 7000 have a much larger (2x) and fixed droplet size.
With color inks in a 10000 CF you will have the same trouble
to keep neutrality as it is with the 9000 etc models, the  LK
isn't there to help.
Ernst
