Paul, that was what I thought. So, to conclude: If I install the UT7 inks in my 7600, with
UC PK in the K slot and LC in the Y slot, I should be able to print with the Epson driver
sliders alone, with a range from neutral to the carbon-warm tone I see with the C86's UT-
EZ (warm) inkset. [pause] Right? :-)
Thanks for your patience and your help.
Sanders.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
wrote:
> Sanders,
> >... if I am not using curves ... printing only with the Epson driver ... ?
> >What happens then, with the Y-position ink?
> When the Epson driver is used with no curves, all the inks are always used.
> When the sepia is taken out and a same-density carbon ink put in its place,
> the print will be the same density but a bit cooler because the carbon is
> not as warm as the sepia.
> Paul
> www.PaulRoark.com
> <paul.roark@v...>
> wrote:
> > Sanders,
> > >...If I install an LC cartridge in place of the Sepia,
> > >am I correct to assume that the combination will still allow me
> > >to print as warm as the C86 UT-EZ warm inkset?
> > >I like the pure carbon warmth ...
> > Yes, you can still print carbon warm when the sepia is replaced with LC.
> > The current UT7 carbon curve uses none of the Y-position sepia ink, except
> > to turn on the black. Now, with the LC in the Y also, you'll be able to
> > have a curves set that has 2 light carbon jets firing, thus increasing the
> > smoothness. I made one such curve for EEM. If it's not posted I'll send
> it
> > to you off list.
> > Paul
> > www.PaulRoark.com
> > <paul.roark@v...>
> > wrote:
> > > Sanders,
> > > >I gather the "Sepia toner" cartridge that gets installed in the
> > > >Y position does not get called for printing the range of warm
> > > >tones permitted by the Epson driver sliders.
> > > The sepia toner, as well as all the other inks, are used when the Epson
> > > driver sliders are used to make a UT7 print. That is why you can shift
> > the
> > > tone range cooler by substituting in a second light warm gray (UT7 LC).
> > > >Certainly, I will never print warmer than the UT-EZ
> > > >carbon/warm inkset for the C86 printers.
> > > Then put UT7 LC in the Y position.
> > > >If this is true, is there any reason not to leave my current
> > > >UC Y cartridge installed in my 7600?
> > > You don't want the UC color inks in there.
> > > The UT7 with the UT7 LC in the Y position is what neutral printers
> should
> > do
> > > for the best prints. You don't want an ink that is not regularly used.
> > The
> > > carbon UT7-LC is the most lightfast ink you can put in that spot, and it
> > > will help the sliders and curves produce the best prints possible. If
> I
> > > did not want to do sepia and wanted to print with the Epson driver, I
> > would
> > > put the UT7 LC in the Y spot (as well as the LC spot). (Use the Y chip
> > for
> > > the Y position.)
> > > Paul
> > > www.PaulRoark.com
> > Please visit the Group Homepage to check the Files, and other resources as
> > they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you wish to
> > unsubscribe, please edit your Membership preferences by visiting this same
> > page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier messages to keep
> > them short.
> > - Good manners are required at all time. No personal attacks or flames.
> > Hostile, aggressive or argumentative users may be removed from the
> > membership without notice.
> > - Keep your posts and threads related to the group topic of digital B&W
> > printing. Users who persistently make off-topic posts may be removed from
> > the membership.
> > - By posting on this forum you agree to abide by the group rules and
> > guidelines, and to abide by the actions and decisions of the group Owner
> and
> > Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU
> > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> > GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF
THE
> > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
> > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
> OR
> > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF
> ANY
> > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Links
> page.
> them short.
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
YOU
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ANY
