Digital BW, The Print
Experiences with new MIS 2200 refill carts ?
2005-01-02 by René Bakker
Dear group,
I noticed on the MIS site, that 2200 refill carts are available (I
didn't found a complete refill kit yet).
What I understand is that the inside of these carts is different from
the original Epson carts.
Because I'm about to buy a refill kit, I'd like to know if anyone has
already used these carts, how the refill process went, and if they
are as reliable as Epson carts.
Thanks in advance,    Rene Bakker
http://home.wanadoo.nl/rene.r.bakker
Re: Experiences with new MIS 2200 refill carts ?
2005-01-02 by Patrick Kealey
I have used the newer carts, and found them more reliable, easier to
refill. they appear, by my experience, as reliable as the epson carts,
have refilled several times with them.
Patrick
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, René Bakker
<gretha.bakker@w...> wrote:
> Dear group,
2005-01-02 by Steven Karafyllakis
The new carts are available for several models; I bought the R300
version, and am quite happy with them. They have been completely
reliable, and are very easy to fill.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, René ‚akker
> Dear group,
from
has
RE: [Digital BW] Experiences with new MIS 2200 refill carts ?
2005-01-02 by Paul Roark
I’m totally spoiled by these new carts.  I don't want to mess with any
others now.  (I wonder if the CFS business isn't history.)
A few issues that I've wondered about with these new carts are as follows:
First, if we are going to be re-using them for a long time, should we be
putting tape over the air inlet holes so that the complex and restricted
inlet design is used properly.  That is, you'll notice the pattern of a
small channel on the top that leads to an inlet.  Then there is a second
inlet that goes straight in.  I think the designers had in mind that the
straight-in fill hole be blocked, and the convoluted, small channel be the
air inlet and be under a label except for the very end of it.  This
restricted air inlet may stop the ink from drying out on the top of the
filter/foam part of the cart.  I've started to tape over the tops of the
carts so that only that small channel allows air in.
Second, when switching carts, I've started to rinse off the outlets before
taping over them to try to minimize the possibility of dry ink getting into
the printer.
Third, I think it might be wise to re-fill or "top off" the carts way before
the printer says they are empty.  I think it might be better to never let
the "filter" (and perhaps ink foam) get dry.
Fourth, the carts start much easier if they are "primed" by pulling some ink
out the outlet with a syringe and a bottom fill adapter.  The idea is to
remove the air bubble that can be left right next to the outlet when the
cart is filled via the fill hole into the reservoir.  (Vacuum filling
eliminated this problem from pre-filled carts.)
So, I fill the reservoir with a 10 cc syringe and MIS needle, put in the
cork, turn the cart partially upside down so that the air bubble is at the
outlet but the ink is still covering the connection between the reservoir
and filter section, then I try the pull out the air.  I notice MIS has an
adapter for UC carts.  I just filed a standard bottom-fill adapter to 7 mm
(the "snout" of it) and, it seems to work.
I'm not sure whether this practice would also be a good idea for a used cart
that has been switched out of the printer for a while.  So far, the used
carts that are re-installed seem to start quickly.  If more that one
cleaning cycle is needed, however, I'd guess air has gotten into the outlet
and a "priming" is warranted.
Anyway, we'll learn more about these carts as we get more experience with
them, but right now, they seem ideal.
Paul
www.PaulRoark.com
Sent: Sunday, January 02, 2005 11:40 AM
Subject: [Digital BW] Experiences with new MIS 2200 refill carts ?
Dear group,
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
Re: [Digital BW] Experiences with new MIS 2200 refill carts ?
2005-01-03 by bfwoolner
<I'm totally spoiled by these new carts.  >
Are these carts available for the 1280??
Barbara Woolner
To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Sunday, January 02, 2005 3:27 PM
Subject: RE: [Digital BW] Experiences with new MIS 2200 refill carts ?
2005-01-03 by Paul Roark
Barbara,
I wish the "easy-refill" carts were available for the 1280, but as far as I
know MIS has not found any.
Paul
www.PaulRoark.com
Sent: Sunday, January 02, 2005 6:19 PM
Subject: Re: [Digital BW] Experiences with new MIS 2200 refill carts ?
Barbara Woolner
page.
them short.
the membership.
Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
Thanks, Paul.  Actually, I'm quite happy using the UT 2 inks but always
looking for a better way.  Best wishes to you and your family for a great
New Year.
Barbara
Sent: Sunday, January 02, 2005 10:22 PM
Barbara,
Paul
www.PaulRoark.com
Barbara Woolner
page.
them short.
the membership.
Yahoo! Groups Links
page.
them short.
the membership.
Yahoo! Groups Links
2005-01-04 by Michael Hung
What about
http://www.inksupply.com/index.cfm?source=html/epsonempty.html#870
"Empty Epson Cartridges"?
Are they "Easy refillable"?
Michael
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@v...> wrote:
> Barbara,
far as I
> Paul
> www.PaulRoark.com
