Digital BW, The Print
Espon 4000 and Colorburst
2004-10-22 by Steve Kale
I took a tour around the PhotoPlus expo in New York today.  At the
Epson stand I viewed samples of the Epson 4000 Pro Colorburst RIP
output on Epson Premium Luster photo paper (UC inks) and was very
surprised to see a very neutral print that had little if any
bronzing.  Maybe it was just the image at hand but the result seemed
very impressive.  Has anyone else taken a look at this combination
for RC B&W?
The Epson package has a version of Colorburst that does not allow
the profiling of additional ink and paper combinations but one can
upgrade to the full version.  It seemed to be very attractively
priced vs what I had heard Imageprint was priced at.  What are
people's thoughts re Colorburst in general?  (Colour or B&W - if
more appropriate please respond off list.)
The President of Colorburst made a comment to me that I did not
understand.  He said that Imageprint treats the printer as an RGB
printer whereas they treat it as the CMYK printer it is designed to
be.  Can someone please explain what he meant by this?
Thanks in advance
Steve
Re: [Digital BW] Espon 4000 and Colorburst
2004-10-23 by James Irelan
don't buy that one
>  but one can
buy that one
I'm getting great color prints using Colorburst with Fotonics and
Darkroom Gloss on a 7600.  I do my own profiling.  Black and white is
another story.  I'm working with another list member to come up with an
IP-like linearization for Colorburst for black and white. After going
through the initial rounds of the project, the b&w prints made with the
new linearization and profile were very close to being neutral in
color.  But, there were some weird artifacts of a type I've never seen.
  In going to their site to post an e mail to their support, I saw where
there was a version upgrade to the RIP, so I downloaded it.  In
trashing the old app and installing the new one, the artifacts were
gone.  And my regular color profile worked fine in terms of image
quality.  But the color is not neutral for black and white.  And when I
tried to load the linearization we had made, the new software version
gave me a new error message:  inks too low.  So I can't even try the
adjustments for black and white that we've worked out.  Consultation
with Colorburst is needed.  They've been pretty taciturn in the past. I
may have to go back to the older version if CB doesn't respond.  In the
past they've responded with one-sentence, cryptic answers that didn't
help any.
He means that CB allows discrete control of the inks- you can send a
CMYK file to it, whereas with IP, you can't (well, you can, but all the
lights on the front of the printer will just flash like mad).  IP does
a good job, though. Colorbyte (IP) refuses to create a "recipe" for you
for black and white if you're not using the UCs, though.
James
2004-10-23 by Martin Sluka
It means that Mr. president of Coloburst is not able to create such
"black box" which IP use as IP president created ;o)
The profiles of IP are profiles of RGB input data + "black box" +
printer inks, head and + paper. Including linearisation and
separation of input data to 1, 2, -, 7, 8 channels (inks). The IP
idea is to control all the most sensitive and the most complicated
steps of process - linearisation, black generation and control of
individual inks. User controls only input data. Simple but sometimes
lack of control.
Colorburst is "clasical" RIP - where user uses his own linearisation
and profiles of printer + paper combo. The separation and individual
inks must be controled by user too. Full control but very complicated.
My 2 cents
Martin
> designed to
Actually, I didn't write this- I responded to it.
James
2004-10-23 by john dean
It seems in regard to rips that Epson is more concerned with the cmyk market for offset
color proofing, posters, and printing from Quark, etc. than they are in creating a fully
functional rip for fine photogaphy. We have a service bureau here who only uses their
9600 for proofing ad work and design work and they make much more money doing that
than outputting photography. Epson wants it all.
