Digital BW, The Print
How Best to Scan older BW Negatives
2004-10-22 by Thomas Keesling
A friend has asked me how to scan a lot of older BW negatives he has
recently obtained. This isn't a topic I know much about, but I do know there
are several of you here on the list that could offer suggestions. Here's
what my friend is asking about.
Regarding the negatives ... there are hundreds ...
they have been stored in little envelopes but have
been handled a lot so aren't particularly clean ...
the majority are approx 3 1/4 x 2 1/4 although some
are 2 1/4 by 2 1/4 ... for my purposes a contact sheet
would almost be okay, however, that process wouldn't
produce very good finished results so guessing I'd
need to have 5 x 7 prints made up, one each, probably
in groups as I can afford ... wouldn't mind sending
them off, but am probably more nervous about this ...
would be nice if it was within driving distance ... I
know that there are scanners that will do negatives ...
perhaps I need to look into one of these but not sure if
they are able to do these large format negatives or just
35mm, of which I have none.
We're in Indianapolis and will appreciate your suggestions. If I haven't
provided enough info, let me know what else you need in order to offer
constructive suggestions.
Thanks...
Tom Keesling
Intelligent Design
Re: How Best to Scan older BW Negatives
2004-10-22 by wharfwalker
'would be nice if it was within driving distance'
Tom,
I could do them for you on a Epson 1640XL, ... it would be a nice
drive too. I am in Grassington, North Yorkshire, UK.
John
2004-10-22 by paulvtt
Tom
I also have a collection of older B&W negatives. I have been
scanning them using an Epson 4800 dpi scanner Model 4870. I have
used scanners with lower dpi niumbers before. Even at 2000 dpi you
will get pretty good resolution.
Whichever you use, be prepared for BIG file sizes. If you use the
maximum resolutions at the higher dpi numbers, you could easily see
file sizes as high as 100 meg. But, for 5x7 prints you really don't
need to go that high.
The Epson 4870 scanner is the one I use and recommend and it's cost
is under $500.00. You could also use an Epson 3200 scanner. They can
be picked up for around $300.
If you want to see more on either scanner, a Google search will
return multiple reviews on each scanner
PV
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas
has
know there
Here's
haven't
offer
> Thanks...
> Tom Keesling
> Intelligent Design
2004-10-23 by steveabrink
I have a epson 3200 for sale with Silverfast Ai and IT8 target for
$250 in case anyone is interested. Contact me offline at
stevebrink@...
sb
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "paulvtt"
<paulv@w...> wrote:
> Tom
can
> PV
> has
> know there
> Here's
> haven't
> offer
> > Thanks...
> > Tom Keesling
> > Intelligent Design
2004-10-23 by Thomas Keesling
Hey, thanks, John. I'll let my friend know. I'm sure he'll want to come
right over. Are you going to be there for the next couple of hours?
Tom
2004-10-23 by wharfwalker
come
> Tom
Tom
The kettle is on... a real English cup of tea piping hot!
John
Coincidentally, Paul, that's the scanner I just purchased last week! There's
currently a $50 rebate for the photo version. I seldom scan negatives and
haven't tried scanning a negative yet. In fact, I've barely had time to
break it in. If my friend decides to scan the negs himself, I can let him
experiment with my new scanner.
Thanks for your suggestion.
Tom
2004-10-26 by Scott Rowed
I'm in a similar situation having to sort through thousands of old
BW negs from medium format through 5x7 negs. There were very few
contact sheets and prints and one of the biggest problems was just
viewing the images to sort them according to content and quality.
The fastest way I found was just to lay the negs on a light table
and photograph them with a digital camera. In Photoshop I set up a
batch that inverted the files and applied auto levels. The results
were surprisingly good. Sure I wouldn't print off them, but for the
initial sorting they were more than adequate.
You could also use a fast scanner for this purpose, but I think the
camera saved a lot of time.
Re: [Digital BW] Re: How Best to Scan older BW Negatives
2004-10-26 by Don Marcotte
Fascinating idea. I do low quality scans of my negs and slides, 35mm and 6x4.5, using a film scanner to get the same outcome. Since I happen to own a small light tablet and a D100.........
Don
Post your free ad now! Yahoo! Canada Personals
2004-10-26 by Bob Frost
Don,
I've used a Nikon Slide Copier on my D100. Another possibility!
Bob Frost.
2004-10-26 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Rowed"
A 6MP camera will give you roughly 3000x2000 pixels.  And since the
the color CCD's in a camera use a bayer-pattern, the actual
luminosity resolution is even lower than that.
On the other hand, a 4000 DPI scan of even a SMALL MF negative, e.g.,
6 x 4.5 cm, will yield 9600 x 7200 pixels.  And obviously it's even
worse for 6x6cm, 6x7cm or 4x5in.   So you are throwing away a TON of
detail, assuming the original negs were reasonably sharp.  You are
probably also thowing away a ton of dynamic range compared to a film
scanner.
MF holds LOTS of detail and lots of tonal-range subtlety.   That's
the whole reason for using MF in the first place!  What you're doing
is taking all your Hasselblads or Mamiya RB67's or whatever and
replacing the film backs on them with a little APS camera.
2004-10-26 by Steve Kale
Err unless I am mistaken the point of the earlier post was to describe a
fast and efficient means of sorting through a massive pile of negs in order
to determine which should be worked on.....
> From: Peter Nelson <pnweb@...>
> Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> Date: Tue, 26 Oct 2004 15:37:33 -0000
> Subject: [Digital BW] Re: How Best to Scan older BW Negatives
> scanner.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
describe a
in order
You might infer that, but he doesn't actually say that.
Here's the original post:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/502
32
Another great suggestion. Just out of curiosity, how well does a Nikon slide copier do in slide to slide film copying? Since I would use the copier on a D100 for indexing in a computerized database, the size of the image isn't important. However, WB would be. Which WB do you use?
One thing I've always wanted to is the reverse of what you suggest. I'd like to be able to put a D100 image onto a slide without paying a king's ransom. My only home-based solution is to print it and photograph it. I don't have a good copy stand so that is really problematic.
Don
Bob Frost <bob@...> wrote:
Don,
Bob Frost.
Yes but the topic moved on from then.  I quote from the post to which you
replied:
 <<I'm in a similar situation having to sort through thousands of old
 viewing the images to sort them according to content and quality.>>
But hey I am not going to argue about it anymore.  ;-)
> Date: Tue, 26 Oct 2004 16:42:31 -0000
> describe a
> in order
> 32
Steve,
Yes, you're right. The point of my post was just to simplify the
sorting task and definitely not to print from. I recognize that this
might not have been a side topic from the original post, but for me
at least, it was a critical part of the workflow since I might only
want prints from 2 or 3 out of 100. And with those 2 or 3, yes
definitely scan with the best scanner available.
Scott
describe a
in order
> > From: Peter Nelson <pnweb@s...>
Rowed"
table
up a
results
e.g.,
even
TON of
are
film
> > scanner.
That's
doing
Don,
The WB (on auto) is better than my Nikon or Minolta films scanners.
Yes, I'd love a cheap film recorder. Why doesn't someone produce one?
Bob Frost.
