Sent: Saturday, August 14, 2004 9:49 AM
Subject: [Digital BW] RE: Scanning Black & White Negatives
Hi Bill,
Thanks for the advise! I am considering getting a dedicated film
scanner. The real thing that is holding be back is that none except
the very (many many thousands of dollars) expensive scanners do not
scan 4x5. That is mainly why I am trying to get at least a decent
scan out of a flatbed for the large format.
I have tried scanning the b&w negative as a color positive as you
suggest & it seems to be no better then any other method. I can live
with the initial scan being either negative or a positive when opened
in Photoshop but the real problem from the standpoint of a good
result is that the scan is bunched up so much at one end of the
histogram that even using levels & curves I end out with a very flat
image when I know the negative is not flat.
what strikes me funny about this is that when I see the scanned
negative in Vuescan it looks perfect, but when it gets opened in
Photoshop it does not seem to be the same scan???
I wonder if I am doing something wrong in the process, but if so why
do all other types of film scans I do come out fine? I don't know.
Bruce
>Hello Bruce,
>I experienced a lot of inconsistency in scanning b&w negatives until
>I adopted a workflow I'd read about from a couple of different
>sources - David Brooks is one I recall.
>I use a film scanner - Minolta Multi Pro II - but the basic
>technique will be the same for your flatbed. basically, I
>deliberately scan the negative in as a color positive. I scan at the
>highest in to out resolution in 16 bit mode and usually set the
>number of passes between 8 and 16 depending upon the amount of noise
>I expect, then get and reset it / rescan it until I'm happy with it.
>Once it's in Photoshop, I'll make level and curve adjustments in
>reverse - it helps if you have a contact or small print from the
>lab. Once it looks like you have a good tonal range go to
>Image>Adjustments>Invert and you should have a fairly decent b&w
>image to tweak from there.
>This is far from an automatic process and does require some getting
>used to working "inside out". But it has resulted in dramatically
>improved scans for me.
>Mr. Brook's article may still be on the Shutterbug site. If so I
>recommend giving it a read.
>I am new to this newsgroup & I hope this topic is correct for the
>group.
>I have gotten aware from black & white since moving to mainly
>digital capture. I am now attempting to re-enter producing black &
>white images in the digital darkroom. I am not new to digital, just
>to digital b&w.
>I currently have an Epson 2450 scanner which works "ok" for medium
>format transparencies. When I attempt to scan b&w negative film
>however, the results are horrible. Here is my two current questions.
>1) How do you get good scans of b&w negative film?
>2) When I scan b&w negative film and then open it in Photoshop, the
>file is still a negative. It has not been converted to a positive.
>Also, the exposure is wayyyyyy off! Always to dark, even though
>during the scanning process the exposure looks fine. What am I
>doing wrong?
>My work flow is:
>Epson 2450 scanner
>Viewscan 7.6.18 scan software
>Photoshop CS
>Epson 2000 printer
>Quadtone for Windows b&w printing software
>By the way, I can print b&w fine with desiderated color images.
>Bruce Varner
>Kansas City metro area
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.734 / Virus Database: 488 - Release Date: 8/4/2004
Outgoing mail is certified Virus Free.
