Question for Paul R.
2004-05-22 by byten2003
I tried putting the light cyan cart in the yellow slot with the ut7 ink and the epson driver wont let it print. Any way around this other than continuous flow or swapping the chip?
2004-05-22 by Paul Roark
>I tried putting the light cyan cart in the yellow slot with the ut7 >ink and the epson driver wont let it print. Any way around this >other than continuous flow or swapping the chip? Frankly, I forget if I used a Y chip or if I used what works on the C82. ON that printer, once a cart is put into its proper positing and "used," its position information is eliminated and it will go into any spot without problems. So, try moving the LC cart form the LC position to the Y position and see if it works. Paul www.PaulRoark.com For UT2 & UT7 information, curves, and settings see: http://home1.gte.net/res09aij/ ___________________________
2004-05-22 by Daniel Staver
> I tried putting the light cyan cart in the yellow slot with the ut7 > ink and the epson driver wont let it print. Any way around this > other than continuous flow or swapping the chip? If the MIS chips behave like the Epson ones it's not going to be possible to change the position without switching chips. -- Daniel Staver http://daniel.staver.no
I just tried swapping the LC and Y in my 2200, and it didn't work. So, you're going to need an Y chip to put on the LC cart for it to be put in the Y position. Paul www.PaulRoark.com For UT2 & UT7 information, curves, and settings see: http://home1.gte.net/res09aij/ ______________________
-----Original Message----- From: Daniel Staver [mailto:daniel@...] Sent: Saturday, May 22, 2004 10:28 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Question for Paul R. > I tried putting the light cyan cart in the yellow slot with the ut7 > ink and the epson driver wont let it print. Any way around this > other than continuous flow or swapping the chip? If the MIS chips behave like the Epson ones it's not going to be possible to change the position without switching chips. -- Daniel Staver http://daniel.staver.no Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
2004-05-23 by byten2003
I just swapped chips. A scalpel to carefully remove the top plastic rivet head and small piece of double stick mounting tape and its done. Thanks for the input all. Charlie
2006-01-12 by georgegeorgakakos
Hi Paul I am using UT2(PK) inks in a 1280 and EZN (PK) in a C86 Could you please tell me whish inks are the same I know that the C86 Y-C-M inks are the same what about the rest thaks in advance g2
