Digital BW, The Print
QTR Question!
QTR Question!
2004-04-09 by Jeff Magidson
Hey Everyone!
I have been trying out the QuadTone RIP and so far I am quite
impressed! The supplied profiles are working quite nicely on my Epson
1280 loaded with UT2 inks. I love the blending curves option.
I have run in to one bug that someone may know the solution to:
I have made several Presets in the print dialog box but for some reason
none of my presets will stick. Meaning, I will configure all my
settings and save them as a preset but when I later go to use the
preset none of my selected settings come up. The settings that where
used for the last print stay in place no matter what preset I select. I
have lots of other presets for the Epson driver that work fine.
Also, since QTR does not employ the Epson driver does anyone know if my
ink usage is still reflected properly in the Epson Printer Utility when
using the QTR with pre filled carts?
Thanks for any ideas on the above!
-Jeff
