Digital BW, The Print
MIS UT & 3000
MIS UT & 3000
2003-12-18 by lovelipp
MIS says they have no immediate plans for outting UT inks in carts
for the Epson 3000 - nor do they have a workflow. So I'm still using
the original qaudtones. Is there anyone else out there who wants UT
carts and workflow for the 333?
RE: [Digital BW] MIS UT & 3000
2003-12-18 by Paul Roark
>for the Epson 3000 - nor do they have a workflow. ...
You have to load your own carts.  It's easy.
I have curves for the 3000 and UT inks.  The 3000 and UT inks make output
that has some visible dots.  For large display prints it'll probably be OK.
The UT-FSN is a new neutral ink that is Piezo/FS compatible and works on the
3000.  There are existing workflows for it, and I'll be making new curves
for it and a pure carbon version.  So, with the Epson driver you get a great
dmax, with the Piezo driver, you get ultimate smoothness.
Paul
www.PaulRoark.com
Re: [Digital BW] MIS UT & 3000
2003-12-18 by Wendel White
> Paul
> www.PaulRoark.com
Paul;
Any word on when MIS will be selling the UT-FSN inks in bulk?
Wendel
Wendel,
I already have some production UT-FSN in bulk.  So, I suspect if you call
MIS they'll sell it now.
Paul
www.PaulRoark.com
_____________________________________
Sent: Thursday, December 18, 2003 9:46 AM
Subject: Re: [Digital BW] MIS UT & 3000
OK.
great
> Paul
> www.PaulRoark.com
Paul;
Wendel
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See Group Topic, Rules and Guidelines in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
To visit your group on the web, go to:
 DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to:
2003-12-18 by Roger L Sopher
Paul,
Does MIS have a sepia toner for the UT-VM ink set? It is my understanding
that with the original VM inks the black and grays were identical in both
the cool and the sepia set, the difference being only in the toner that is
used. Would this also be true of the UT version of VM?
Roger
  Sent: Thursday, December 18, 2003 2:34 PM
  Subject: RE: [Digital BW] MIS UT & 3000
  Wendel,
  Paul
  www.PaulRoark.com
Roger,
Sort of -- I mixed a light toner for the Bowhaus system that will pull the
warm gray UT inks to sepia.  But in a single-toner inkset, the most neutral
you'd be able to get is the current UT warm.
> It is my understanding that with the original VM inks the black
>and grays were identical in both the cool and the sepia set,
>the difference being only in the toner that is used.
No, the grays used in the VM-S inkset were the same as the FS-N grays.  That
is one reason the FS-N gray was cool.  It was to keep the tones of the VM-S
inkset neutral further down into the shadows.
One problem I have with the VM-S inkset is that first the grays had to be
toned cool to get a neutral.  Then we added more color pigs to get it warm
again -- too much color for me.
I suppose if you have a quad and wanted a UT-VMS, the new UT-FSN could be
used with a stronger UT sepia toner, but it, again, would have to use more
color to get the sepia than the UT-2 dual toner approach can achieve.
Paul
www.PaulRoark.com
  Wendel,
  Paul
  www.PaulRoark.com
page.
them short.
the membership.
Yahoo! Groups Links
Carrying on with the same idea, more or less, do you think one could use the
sepia toner from the current vm-s quad set with the UT-FSN black & grays to
approximate vm-s or is the ink chemistry simply not compatible between the
two formulations?
Roger
  Sent: Thursday, December 18, 2003 4:06 PM
  Roger,
neutral
        Yahoo! Groups Sponsor
2003-12-19 by Paul Roark
Roger,
>... do you think one could use the sepia toner from the current
>between the two formulations?
It would probably work, but the curves would need tweaking.
Depending on the printer, I might be more inclined to just mix a sepia toner
with about 15% each of MIS 7600 Y & M, with the remainder a light gray, like
the UT lightest gray.  (The light gray cuts the gamut of the toner and helps
hide the dots.)  That keeps the chemistry in the UT family, which has a
number of advantages.
One advantage of mixing your own is that there is a wide spectrum of sepia
tones.  You might as well take control of that variable so you can mix just
what you want by varying the yellow/magenta ratio.
Paul
www.PaulRoark.com
  Roger,
neutral
page.
them short.
the membership.
Yahoo! Groups Links
