Digital BW, The Print
BO with Eboni
BO with Eboni
2003-11-22 by Lincoln Michaud
Hi Folks,
I am new to b&w printing and trying to get up to speed on all the
wonderful new options available today. I have the Epson 1280 printer
and have been venturing into the MIS inks.  I was very pleased with
the 1280's color prints and saw some very interesting possibilites
grayscaling some of my color stuff and printing BO.
"Black Only" seems a less steep learning curve than systems such as
quad tones and my initial results were very pleasing. I basically
converted my color images into b&w scans using the channel mixer and
printed  with a simple profile. I got a clog in my black cart that
did not want to go away(yes I tried all manner of cleaning cycles) I
popped in my original Epson inkset that came with the 1280 and was
able to get rid of the clog. I also noticed that the blacks got
blacker in my images (which I understand is a property of the less
archivable dyebased Epson inks)
However, when revisiting the  MIS site,  I noticed that they now have
an Eboni black as part of the Ultra tone set which is supposed to be
a blacker  black on the EEM I like to use. I like the idea of a more
archivable injet print.
Questions:
1. Can I pop in a MIS eboni cart next to the non-Ultra tone MIS color cart?
2. Will the eboni cart work if it is installed next to the Epson color cart?
(Obviously, my intent is to use up the color cartridges during
cleaning cycles without chip to chip conflicts)
3. I notice a marked improvement when printing at 2880 instead of
1440. In order to have the 2880 setting made available to me, I have
to choose a paper setting that is other than the matte I am using,.
Should I do something specific to the profile to otherwise compensate
for this change?
I apologize if these items have been already thoroughly discussed in
the archives. The archives (even considering all the info they have
already given me), tend to ramble on and it is difficult to target
specific questions.
I welcome your comments,
                                Lincoln
Re: BO with Eboni
2003-11-22 by morganbaily2001
Lincoln...I have a 1270 and have put in the Eboni cart with epson
color carts and dont have any problems with either.  I have been
using 1400 dpi and have had good success.  Many in this group say
that u have to go through a cleaning cycle before putting in the
Eboni to avoid clogs but I have not had any problems whatsoever.
Good luck
Rick Zeidman
www.morgan-baily.com
- In DigitalBlackandWhiteThePrint@yahoogroups.com, Lincoln Michaud
<outdoornewmexico@y...> wrote:
> Hi Folks,
printer
and
I
have
be
more
> Questions:
color cart?
color cart?
have
compensate
> for this change?
in
> specific questions.
>                                 Lincoln
Re: BO with Eboni
2003-11-22 by outdoornewmexico
Thanks Rick,
Did you notice that your blacks were "blacker" when using the
eboni cart?  Of course, if you are only printing color, it may be
difficult to tell.
I have a feeling that any improvements between 1440 and 2880
dpi print settings may be very content dependant.  I printed
several b&w  New Mexico White Sands shots and some parts of
the images showed improvement (strong textural elements)and
others didn't seem to make any difference.  Of course, if you are
impatient  to wait for the slow 2880 printing time- you could
convince yourself there ain't any improvements.  :-)  I used "print
preview" to organize two identical images side by side(1440
vs2880) so as to save paper and make a direct comparison.
                             Lincoln
-- In DigitalBlackandWhiteThePrint@yahoogroups.com,
epson
been
group say
whatsoever.
> Good luck
> Rick Zeidman
Michaud
> > Hi Folks,
1280
> printer
pleased with
possibilites
systems such as
basically
channel mixer
> and
cycles)
> I
and was
less
now
> have
supposed to
> be
> more
> > Questions:
> color cart?
> color cart?
instead of
I
> have
using,.
> compensate
> > for this change?
discussed
> in
have
> > specific questions.
> >                                 Lincoln
Re: BO with Eboni
2003-11-22 by Bob Michaels
Linc:
You'll find a some people in this group that disparage Black Only
printing and believe it's just inferior to quad or hextone. But, I
sure am not one of them. It works better for me in some images. You
should see the Black Only print that Richard has in the recent ContaxG
print exchange. It was a "WOW!" as his prints usually are.
I'm about to switch over to Eboni black and UT as soon as my current
bottle (G4 black with FSN-E lighter tones) starts to run low. I don't
think the Eboni is appreciably darker but everyone says it's a better
ink all the way around. I would be hesitant to use Eboni along with
color dye ink as Paul Roark & MIS say that combination can cause
clogs. I think there could be traces of the dye ink picked up on the
black head from the waste pad (below the print head when it's at rest)
and cause potential clogging problems. (someone correct me if you're
doing it successfully)
I can see no difference between printing at 1440 and 2880 dpi other
than print time. For once, I seem to be in the mainstream line of
thinking. But if 2880 works better for you, by all means use it.
Now you have no excuse for not being in the next ContaxG print exchange.
Bob Michaels
 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Lincoln Michaud
> Hi Folks,
> Questions:
color cart?
color cart?
> for this change?
> specific questions.
>                                 Lincoln
Re: BO with Eboni
2003-11-23 by outdoornewmexico
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob
Michaels" <bob@b...> wrote:
> Linc:
Only
images. You
ContaxG
*-Hi Bob,
I'm sure Richards image was excellent.   I guess I don't consider
myself smart enough to just jump into quad or hex prints. In
addition to that, some of the samples I have been trying in BO
really blew me away!  They have a 3 dimensional quality I had
not been expecting.  I think part of this is due to the fact that
photography in the White Sands lends itself to BO.  Also, the
bright white of EEM  showing thru' the images really gives them
an elegant "pop".  Even though I am a fanatic about resolution,
the '"dots" seem rather '"honest" to me and you have to be
looking for "trouble" to really notice them.  Normal people (not
including photographers, architects, engineers, optical
designers and other fanatics),  would really not notice.  :-)
current
don't
better
*--I would be happy hear how you make out with UT.
with
cause
at rest)
if you're
*-- I really just plugged in the Epson dye base inks because my
MIS cart had a clog I could not remove.  I wish I hadn't used the
dye base cart now.
other
of
*-- Well, I can see a pretty significant diff-- as I wrote before, this
may be due to the fact that I am primarily working on White
Sands images.
exchange.
> Bob Michaels
*--- Maybe, we'll see if I can get anything good to submit.  At least
if it is b&w I might get a glimmer of credit.  :-)
                     Linc
Re: BO with Eboni
2003-11-23 by Clayton Jones
Hello Lincoln,
have
I do BO printing and recently switched to Eboni after using the MIS
FS-K for a long time.  The term "blacker" can mean different things to
different people, so here's what I learned - Eboni is a bit warmer
than fresh FS-K, but not as warm as FS-K after it has warmed.  The
testers say that Eboni warms so little as to be negligible, so the
long term result of Eboni is a cooler tone.  Both have excellent D-max
>1440.
I find that the resolution in fine details is much better at 2880.
>compensate for this change?
I print at 2880dpi on a 2200 and use the matte paper setting.
Clayton
Re: BO with Eboni
Hello Bob,
>printing...But I sure am not one of them. It works better for me
>in some images.
Nice to see you in here standing up for BO printing.  Hooray!
I switched and love the results.
>I don't think the Eboni is appreciably darker
See my reply to Lincoln about being "blacker"...
I switched to a 2200 at 2880 dpi and find that the resolution in fine
details is _greatly_ improved, and the "gritty" look is gone.   I do
everything at 2880 now.  As far as appearance, I think the 2200
handles 2880dpi differently than the 1280 does, and it's also faster.
 It's about as fast at 2880 as my 870 was at 1440.
Clayton
Re: BO with Eboni
Clayton wrote,
MIS
things to
warmer
The
D-max
*-- Thanks for the explanation, Clayton
By the way, your strong endorsement of the BO technique was
one of the reasons I decided to give it a try. Thanks, I'm glad I did!
  The luster of EEM really shines thru' in my White Sands
images. Hearing about it is one thing, seeing the results is very
refreshing.  The clouds really do have a "silver lining" and sand
textures are delicious. I just hope that  mounting under glass
does not kill the effect.
instead of
> >1440.
using,.
> Regards,
> Clayton
*--If you choose "Heavy Matte Paper"  with the  1280,  you cannot
select the fine 2880 print setting(grayed out).  This may be an
improvement with the 2200, or maybe just a way to allow you to
print at 2880. I can see no drawbacks when printing matte on the
"high gloss" setting. I was just concerned that the "high gloss"
setting might cause the ink to be layed down differently   ie-less
thick to prevent pooling on a gloss surface.
 Thanks for your help , Clayton!
                      Lincoln
[Digital BW] Re: BO with Eboni
Alan wrote,
> >I think someone should start a BO list  :-)
*--Naa, it's just a diff medium.  Diff' but not lesser.  I can see
some images that will just look better with something like the UT
system.
> >I've been using BO for a book project on a new 1280 and with
refilled
> >carts.   After about five full tanks of black - I haven't had to run
a
> >cleaning cycle yet - the color cart level indicator shows it is
nearing
> >empty.
*--Alan, you can't depend on the onscreen cartridge level
indicators. They are generated according to how many sheets go
thru' the printer, rather than how much ink is actually used. I have
heard of some problems if a color cart runs out and you do not
notice it. (Drying out?)
  What gives?  Some genius ought to figure out how to use only
one
> >color tank at a time to give an assortment of BO choices.
*-- You've got something there. What if you got MIS to fill the
complete color cart with eboni?  One time you coul print  "c" , one
time "M".... and so on.   This way, you could use up all the ink.
> Anybody got a fave BO paper?  I know that depends a lot on the
image.  My
> book project has been on Red River #32 Premium Matte
printed one-side, with
> little show-through.
> AZ
> Build a Lookaround!
> The Lookaround Book, 2nd ed.
> NOW SHIPPING
> http://www.panoramacamera.us
*-- I checked out your web site--you've got some pretty interesting
panoramic photos there!
               Lincoln
Re: [Digital BW] Re: BO with Eboni
2003-11-23 by Alan Zinn
At 07:11 AM 11/23/03 +0000, you wrote:
>Hello Bob,
> >in some images.
>Regards,
>Clayton
Clayton,
>I've been using BO for a book project on a new 1280 and with refilled
>carts.   After about five full tanks of black - I haven't had to run a
>cleaning cycle yet - the color cart level indicator shows it is nearing
>empty.  What gives?  Some genius ought to figure out how to use only one
Anybody got a fave BO paper?  I know that depends a lot on the image.  My
book project has been on Red River #32 Premium Matte printed one-side, with
AZ
Build a Lookaround!
NOW SHIPPING
Re: BO with Eboni
2003-11-24 by Clayton Jones
Hello Lincoln,
>I did!
You're welcome.
Wait until you try Photo Rag!  (You aint seen nuthin yet <g>)
>...in my White Sands images.
It must be great to live out west.  I'd love to spend a lot of time
photographing out there.
>The clouds really do have a "silver lining" and sand textures
Please let us know what your impressions are after you get some
mounted.
> print at 2880.
Ah, I didn't know that.  It's different with the 2200.
Well, it's the final result that counts.  I guess it's worth trying
all the settings to see what happens...just use the one that gives the
best results.
Clayton
Hello Alan,
LOL!  No need for it, really.  It just needs to be treated like any
other method.
>refilled carts.
Sounds interesting, what kind of project?  What ink?
>haven't had to run a cleaning cycle yet - the color cart level
>indicator shows it is nearing empty.  What gives?
You know how the print head pauses a bit after every 10 or 12 passes?
 During that pause the head is way over to the left side and I think
it does a little head cleaning squirt of the other nozzles, so the
color inks gradually get used.
I prefer PhotoRag for final prints (work prints on EEM).  I love the
look and have no flaking problems when I give the paper a rub with a
soft cloth.  Prints worked up with EEM can look a tad light on PR, so
I use a simple curve layer to pull them down.  I place a single
adjustment point in the center (I/O 128-128), and pull it to the
lower-right a few inits to I/O 131-124 or 133-122, depending on the
image.
Clayton
2003-11-24 by Alan Zinn
At 01:11 AM 11/24/03 +0000, you wrote:
>Hello Alan,
>other method.
> >refilled carts.
>image.
>Regards,
>Clayton
Clayton.
I'm using plain old MIS ESC 1270-2-K  .  When that's gone I'll try some
Ebony. Maybe a cheap skate like me should fill the color cart with Windex
rather than waste good ink.
The book is the one on my tag line. I have six pages of 11 x 17 folded, BO
pics and about 30 pages of  8-1/2 x 11 printed  and comb bound.
Thanks for the paper info.  Someday when I have some time I want to try
mixing own dye/pig combo and also try double hit black.  Next I'll look
into varnishes.
AZ
Build a Lookaround!
NOW SHIPPING
