RE: 2200 inkpositions from Daniel Staver
2003-10-31 by twelch2113@aol.com
Daniel, I have been using the septone inks and plug-in but have not been completely satisfied with the D-max and depth of the tonal range. Rather flat compared to my 1160 with mis quad inks and generations black. I tried print without using the septone plugin and using the epson driver with a curve and suddenly my 2200 came alive . I am thinking of trying the ultratones in my 2200 cis that now has the septones in it. I will have to do a swab test and figure out where the current ink positions are located. My question to you is about the Arvchival 7600 light black ink. Is it epson or MIS. Have you had any clogging with the Eboni black? I have been using the Entrada and photorag paper. Where is this Premier Paper coming from. I don't remember reading about it. Thanks Tom Welch > > [Non-text portions of this message have been removed]
