Digital BW, The Print
matting quadtones
matting quadtones
2003-09-23 by Mark Hahn
looking for a good cheap source for pre-cut 16x20" 8-ply museum mats
in the US.  Also, how are people hanging their quadtones in a mat?
Hanging some stuff in a gallery and all the local shops are stupidly
expensive...
thanks,
mark
RE: [Digital BW] matting quadtones
2003-09-23 by Ron at BookCrossing.com
> expensive...
Good questions! Along those same lines, I'd be curious to hear hear if/how
people are dry-mounting their digital prints. I've got an old 20x24 Seal
dry mount press from my silver-printing days that I'm hoping will work
with the new media. My old method was to dry-mount, then cut a window mat
about 1/2" from the print border all around, with a little more space at
the bottom for a penciled signature. The glass is then kept off the print.
Any opinions on the appropriateness of that method would be appreciated!
-Ron
Re: matting quadtones
2003-09-23 by photographs42
Dry mounting works fine. I use colormount at 200 deg. If you are
using a textured paper, it works best to use a sheet of the same
paper for a cover sheet.
Jerome
http://www.jeromehawkins.com/
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ron at
mats
stupidly
> > expensive...
if/how
Seal
work
window mat
space at
print.
appreciated!
> -Ron
Re: [Digital BW] matting quadtones
2003-09-23 by Jalopy100@aol.com
From my experiences, the dry mount works just fine with digital prints
2003-09-24 by Alan Zinn
>expensive...
>thanks,
>mark
Mark,
Go to Light Impressions:
www.lightimpressionsdirect.com/
http://www.lightimpressionsdirect.com/servlet/OnlineShopping?Dsp=20300&PCR=30000:230000:234000:234100:234130&R=8466
the 8-ply
8 ply is pretty extravagant -never had the nerve to pay the $$$.  I have
both dry-mounted, used tape, or corners. It depends on the rebate around
the image.
Don't really need dry mount because the paper stays very flat.
AZ
Build a Lookaround!
The Lookaround Book, 2nd ed.
http://www.panoramacamera.us
