Digital BW, The Print
Re: [Digital BW] help with developing problem NEW PROBLEM
2003-05-23 by DigitalLipothymy@aol.com
hi
i too am having problems with developing my first roll of 120 film
i am not sure if it is because my chemistry is old, or the fact that the film
came off the roller while it was in the tank :)
either way, all i got was a strip of film, with "psychedelic purple" streaks
all over it, with little image showing beneath
any idea what went wrong?
thank you
2003-05-23 by Stephen Petegorsky
Purple spots on the film indicate areas that did not get fixed properly.
The odds are, from what you described, that when the film came off the reel
it was no longer separated from other parts of the roll, and thus one part
of the emulsion stuck to the base of another part of the film.  It's likely
that those areas would be neither developed nor fixed, but since the fixer
clears away the parts of the emulsion that haven't been developed or
exposed, anything that remains (and that will look like unprocessed film)
has to be an area that didn't get fixed.
If you haven't already, practice loading the reel with an expendable roll of
film.  Do it with your eyes open at first, so that you can see how it has to
go, and then with your eyes closed until you're really comfortable with it.
THEN go back to the darkroom!
In a message dated 5/23/2003 2:08:57 PM Eastern Daylight Time,
petegorsky@external.umass.edu writes:
yes, that is what i was thinking too
although, my chemistry is pretty old as well. what is the Rule of Thumb
as far as expiration on B+W chemistry goes? there are no expiration
dates on the bottle of chemistry
-----If you haven't already, practice loading the reel with an expendable
roll of
that is exactly what i have been doing all morning! :)
thank you!
Some chemicals will tell you (in fine print) how long a solution will last
if diluted in a certain way and if stored in a certain kind of container,
etc.   It's really a question of the individual chemical, not even whether
it is developer, stop bath or fixer!
2003-05-23 by Truman Prevatt
From the description of the inperfections it doesn't sound like they
came from emulsion touching base - hence no development. My first
thoughts was film that had been exposed to heat. My second thoughts was
a problem with the fixer. Sometimes you need to shake the fixer in the
storage bottle before you pour it in.
It could have also been air bubbles but you usually see those. Also
depending on the water supply there may have been very fine particles
suspended in the water that hung to the emulsion and that blocked the
developer.
There are a number of reasons this could have happen. I'd start with
exposing two rolls of film to a fixed target. Then develop ( and fix)
one in distilled water and the other tap water, to rule out my water as
the source. If both suffer the same problem, I'd note the lot on the
film and contact Ilford.
Truman
>Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- Include your full name with your message.
>- Include the address of your website, if you have one.
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- As the topic of a thread changes remember to change the subject header.
>- Good manners are required at all time. No personal attacks or flames
>- Complete your Yahoo profile.
>- Before posting a question, search the message archives and the various resources on the homepage.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
In a message dated 5/23/2003 3:45:56 PM Eastern Daylight Time,
tprevatt@... writes:
the plot thickens: i called a camera store today, and described to them
what happened, and i was advised to refix the negatives and see what
happened.
so, i did that, and then instead of the psychedelic tie dyed purple, i got
a clear, barely there lavender shade, where it looks like none of the film
was exposed, although some frames have the name of the film and number
above them, but no image in the frame itself
any ideas what i did wrong?
i am using a Medium Format Camera that i am not familiar with, and my
guess is that although the film advanced, it somehow didn't get exposed
properly
thank you!
