Re:Ink-jet better than wet prints (was Digital stuff)
2003-05-22 by HPA
> --- Anthony Atkielski <anthony@...> wrote: >> What is silver extrusion? >> > Silver extrusion is when due to poor processing, the > silver in the paper begins to show through. It looks > like the silver is sitting on top of the image. This > is usually due to a lack of sufficient wash time with > no hypo clearing agent used. It takes years to happen. > It can be a challenge to minimize it with traditional > copy methods. Not too tough with digital. > > Evelyn To be specific, the problem is called "silver sulfide staining". They appear on prints as a metallic sheen. It is a very common problem and can affect any silver photograph, even archival process, over time. The problem is commonly known as ordinary silver tarnish. I have observed numerous examples dating as recent as the 1970s. The only known way to remove the stain by copying is by cross polarized light. This is accomplished with filters on your light and your lens. The polarizing sees right through it with no problem. Full instructions are on pg. 54-55 of Kodak's "Copying and Duplicating" and this shows several examples. I understand this can be done with a digital camera, however I have never tried that. I know that it is not possible to modify a flatbed with polarized light as described above because the scanner will fail it's calibration cycle. For physical removal of the staining from prints or negatives, see the extended tutorials in "Fundamentals of Photograph Conservation: A Study Guide" by the National Archives of Canada. I have been doing these treatments for ten years now. I can attest from experience that copying with cross polarized lights is so effective that it is unnecessary to do any further treatment in the scan of the resulting film copy, plus you pick up a full f stop of shadow detail. This approach yields a much better digital file than any direct scan of the deteriorated original. This information applies only to prints, deterioration of negatives is an entirely different treatment. Thomas Robinson
