Agree 100% with Helene. This was pretty much what I would have done
before trying many of your cleaning solutions. Unless you have an
unlikely hugeamongous clog right at the bottom of the nipple where it
does a right angle turn (AFAIK) and thereby would choke off the whole
nozzle pattern, this is almost certainly an air block- or lack of CIS
delivery.
I'd bet that your CIS is the problem...popping in an Epson cart will
tell you if it's the head or the CIS AND clean the head out a little
which can't hurt it.
A lot of folks try to recover a CIS and a good method would be to
remove ink from bottom with syringe and optional bottom fill adapter
and return to bottle, repeat. Since it's the K cart you might want to
consider just replacing the cart, snipping the old off at the tubing,
then recharging.
I'm not surprised at all it is MIS inks clogging- I had more problems
with them than the old Cone PiezoBW inks- CLOG wise. PiezoBW for me
had far greater problems though...can't speak for the new MIS inks.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, grdglass@a... wrote:
> Sticking in an Epson OEM cartridge (brand new) is a great idea. It
always
> works for me. You could have air in your CIS rather than a clog, BTW.
> Helene
> > Ugh got a real bad clog on my 1160. CIS Black ink.
> > Have tried all the usual solutions. Both liquid and mechanical.
Cones
> > tips and tried ammonia and alcohol. Also some strange
cleaning fluid
> > from that company in Las Vegas. Did not work.
> > I hardly get any ink coming out of that nozzle, the numbers don't
even
> > print.
> > I suppose I have to get it serviced.
> > One last idea was to get an original Epson black cartridge and see
if that
> > ink will open up the nozzles. Does anyone think that is a good
idea or
> > are
> > there some new ideas for cleaning . I have not looked around for
cleaning
> > ideas since last summer.
> > I need to start making some new B&W print quadtones. By the way
this clog
> > is with MIS inks!!!
