Digital BW, The Print
Self Inflicted Posterization
2003-03-17 by Kevin Gulstene
Aaargh-
I've been having problems with posterization introduced into a PS7
file, that is very slightly visible in the print.
The image has very similar tones around each of the four edges of a
greyscale image.  To help with the center of focus I want to darkening
the edges.  To do this I make a rectangular selection, invert the
selection and then feather it by 50 pixels.  When a curve is applied to
the selection the feathered edge has 'bands' in it.  It is not a smooth
looking transition but steps in concentric bands from tone to tone --
I'm calling this posterization.  It is not that obvious but once I know
it is really distracting.
Adding a small amount of noise to the image mostly removes the
posterization but (and it may just be my imagination) leaves a less
smooth texture to the image.
So, is there a better way to make the selection without introducing the
banding/posterization?  Is it better to go around the edge with a big
soft brush and paint it in the selection?  Is there a setting somewhere
that will introduce some dithering or noise in the feathered area?
I tried making the curves on a 16 bit image after loading the
selection(s) from the adjustment layers of an 8 bit version but got the
same results for the most part.
Any suggestions are appreciated.
Kevin
