Contact prints redux
2002-11-12 by Stephen Kobrin
I asked the original question about contact prints and with the help of the group and some tinkering have been able to produce more than statisfactory contacts with a HP Scanjet and PS7. My "workflow" is: Put the negatives in their plastic holder in the scanjet with a sheet of white paper on top and after the prescan, crop, set the resolution to 300, grayscale, and fiddle with the middle slider until the prescan gets close to looking like negs on a lightbox. (A plate of glass or heavy white board would have kept them flat.) Scan into PS, invert. Then levels to use the middle slider to adjust the image. Then a layer in overlay blend mode at 100% opacity to add density to the image. Burn where necessary and sharpen. I printed on EAM with a 1200 using the Roark VM curves set to mw. The contacts are far from perfect, but certainly serve their purpose. One advantage of digital contacts is that you have some control over individual shots. The whole thing took less time to do than to describe. Steve Kobrin
