Digital BW, The Print
Epson 4800 - Service Req 0001001D
2016-06-10 by mccarvill@...
I'm getting this error (and the printer literally grinds to a halt) on my 4800 whenever it’s about to begin a print job, or even do a nozzle check. It started off as an intermittent problem that would go away for a week or two after I turned the printer off and on, but now I can't print because of it.
I've tried the obvious and easy fixes first – e.g. there are no paper jams or debris, the carriage lock isn't engaged, etc. Still no luck.
Suggestions?
RE: [Digital BW] Epson 4800 - Service Req 0001001D
2016-06-10 by Nigel Richards
It might be worth doing some searches on the web, Epson document it at
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=FAQ <http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=FAQ&oid=57105&foid=60050> &oid=57105&foid=60050  and it is mentioned by many others.
Most suggest it is a carriage movement or an encoder strip problem.
Cheers
Nigel
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]
Sent: 10 June 2016 20:37
Subject: [Digital BW] Epson 4800 - Service Req 0001001D
Suggestions?
Re: Epson 4800 - Service Req 0001001D
2016-06-12 by mccarvill@...
For now, I've appeared to have solved the problem.
The printer shares a power bar with a floor lamp, which seemed to create an electrical surge or imbalance, especially when the printer was about to start a print job. Turning off the lamp before sending a print job allows the printer to work normally. Eventually, I'll find a dedicated wall socket for the printer.
