Digital BW, The Print
Re: (no subject)
Re: (no subject)
2016-01-09 by arlenelove3@...
It is my understanding that Epson K3 ink is archival, and also the carbon
inks from Jon Cone and MIS ...all pigment. Are there any archival  pigment
inks for Canon or HP?    I had good B&W  results with K3 and HPR paper.  The
MIS inks were great, but I spent more  time with my head inside the printer
than making prints. I used MIS with an  Epson 3000 and 7600. With the 7800,
I caved in and used K3. I am not planning to  buy another 24" printer, and I
have some 220 ml carts to sell.
                                 Arlene
_arlenelove3@..._ (mailto:arlenelove3@...)
Re: [Digital BW] Re: (no subject)
2016-01-09 by Bill Kennedy
Arlene-
Not to split hairs but there really is no such thing as "archival" inks, papers or prints. If you have a minute:
http://theagnosticprint.net/defining-archival-standards-in-photography-2/
That said, both Canon and HP offer color pigment ink sets for their professional printers, but I think your looking for third party inks instead? The last time I checked, and its been a while, the HP Vivera inks tested very well compared to Canon or Epson. FYI, the grayscale output of the HP professional printers is the best I've seen from using a color ink set.
Bill Kennedy
Professor of Photocommunications
Area Coordinator
St. Edward's University
Austin, Texas USA
From: arlenelove3@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com>
To: DigitalBlackandWhiteThePrint <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Sat, Jan 9, 2016 12:19 pm
Subject: [Digital BW] Re: (no subject)
It is my understanding that Epson K3 ink is archival, and also the carbon inks from Jon Cone and MIS ...all pigment. Are there any archival  pigment inks for Canon or HP?    I had good B&W results with K3 and HPR paper.  The MIS inks were great, but I spent more time with my head inside the printer than making prints. I used MIS with an Epson 3000 and 7600. With the 7800, I caved in and used K3. I am not planning to buy another 24" printer, and I have some 220 ml carts to sell.
                                Arlene
arlenelove3@...
2016-01-09 by John Castronovo
In what way are they better? If it’s a matter of uniformity and Dmax, then a rip and better profiling could change that.
From: mailto:DigitalBlackandWhiteThePrint@yahoogroups.com
Bill Kennedy
Area Coordinator
Austin, Texas USA
Right you are. My post was unclear. I should have added "OEM" or "out of the box".
Bill Kennedy
Area Coordinator
Austin, Texas USA
From: 'John Castronovo' jc@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Sat, Jan 9, 2016 1:01 pm
Subject: Re: [Digital BW] Re: (no subject)
Bill Kennedy
Area Coordinator
Austin, Texas USA
2016-01-09 by Paul Roark
Arlene,
FWIW, here is my take on it, and I've studied Mark's outstanding work at Aardenburg Imaging and done my own testing.
There is no precise definition of "archival." It's a question of how much you need or want. There are trade-offs between the ultimate in archival -- both lightfastness and physical substrate reliability -- and other desirable attributes of the B&;W medium.
Carbon is significantly stronger than the best OEM color pigments. The OEM color pigments are the best color.
The OEM grays are not 100% carbon. They are blends of carbon plus colors. Thus they are not up the the 100% carbon of the Eboni-6, MIS K4-LK, LLK (and some of the B&W glossy ink positions in UT7, etc.) and Jon's Carbon Sepia.
The third party blended carbon-color inksets are not as good as the OEM blended carbon-color neutral inks. HP PK and gray have been my favorites for blended neutral inks for some time (but they really bronze unless an MIS glop type dilution base is used).
I have never tested or seen a test of the Epson K3 LK, but it9;s probably going to be in my next fade test.
Beware of the blended carbon + color B&W inksets. They are good enough for most purposes, but the color in them does not appear to be as stable as the OEM blends. Controlling the color shifting as the color pigments fade deferentially is the largest challenge.
Their pigments are excellent, but all of them use more color than needed for B&W. Thus they are a notch down from what we can do. By taking control of the carbon to color blend, we can do better with custom inksets. You'll note, however, that I use Canon color pigments for my toner in the Eboni variable tone inksets, and I use HP PK & Gray pigments for the best pre-blended neutrals.
The OEM systems are just fine for most users unless you want to save money or take it up a notch to a higher percentage of carbon (which is the ultimate B&W imaging substance for what we do) and many more carbon channels firing for smoothness.
Paul
