Proofing paper for Eboni 6 on Epson 1400 and Arches Bright White
2015-03-17 by brubaker_family@...
Is there an inexpensive proofing paper anyone has found to help get an image set up to print Eboni 6 on Arches Bright White watercolor paper? The Arches BW is pretty expensive to make mistakes on.
Mike Brubaker
2015-03-17 by Jacques Caron
Hi I don't know if you can exchange papers making tests; working on a 1430 with Eboni 6, I've found that the best way is to buy the size that you want as output and at the same time, buy the smallest size available for the same paper. Much more economical and, at least, your tests will be on the same paper as the final result. Good luck Jacques Le 2015-03-17 à 13:41, "brubaker_family@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com> a écrit : > > Is there an inexpensive proofing paper anyone has found to help get an image set up to print Eboni 6 on Arches Bright White watercolor paper? The Arches BW is pretty expensive to make mistakes on. > > > > Mike Brubaker > > > > > Jacques Caron Photographe jacques.caron@...
2015-03-17 by Edward Wiseman
I’d try Red River 60lb polar matte 2-sided..Prints on both sides.. like 100 letter size sheets for about as cheap as it gets..also a very nice matte paper for around $35… I’m using it with UT-14 inks! Good luck with what you choose! Eddie
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@...m] Sent: Tuesday, March 17, 2015 1:42 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Proofing paper for Eboni 6 on Epson 1400 and Arches Bright White Is there an inexpensive proofing paper anyone has found to help get an image set up to print Eboni 6 on Arches Bright White watercolor paper? The Arches BW is pretty expensive to make mistakes on. Mike Brubaker
2015-03-17 by richard@...
2015-03-17 by brian_downunda@...
2015-03-18 by richard@...
2015-03-18 by brian_downunda@...
2015-03-19 by Brubaker family
Thanks to all for their responses. Brian is right about what I want to do with "proofing." Since the 1400 is a 13 X 19 printer, I can get two 13 X 19 (starts out at 13 X 22 but I will then trim to 13 X 19) sheets and three 4 X 6 and one 4 X 4 out of a 22 X 30 sheet of Arches BW. I can use the 4 X 6s for post cards or proofing and the 4 X 4 for proofing. For proofing I can use both sides. That may be enough, but I was seeking an alternative in case I needed one. Mike Brubaker -------------------------------------------- On Tue, 3/17/15, brian_downunda@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Subject: [Digital BW] Re: Proofing paper for Eboni 6 on Epson 1400 and Arches Bright White
Date: Tuesday, March 17, 2015, 7:42 PM
The OP said proofing paper, not profiling paper.
I assume he wants to perfect an image by printing iterations
on a cheaper paper before using an expensive paper to print
a final. I can relate to this. I use EEM as a proofing
paper at 60 cents an A4 sheet, rather than HPR or CRP at
nearly $2 per A4 sheet and $4.50 per 13"x19" sheet
($AUD prices).
However the
problem comes when you switch from the proofing paper to the
final paper. It's going to be hard to find a paper
that's a close match. Even if you do, you need to have
a very good handle on soft-proofing both papers in order to
make the switch fairly seamlessly. I'm using
Piezography rather than Ebony, and if you have piezo curves
that are exactly linear for both papers then you'd go
close, although even then you'd get differences. For
example, HPR has a higher dmax and so you'd typically
get blacker blacks. So having accurate soft-proofs and a
screen that can simulate the printing environment (e.g. Eizo
CG) and being able to reliably interpret the soft-proof is
essential IMHO.
If you use
your ICC profiles for conversion rather than soft-proofing
and printing in GG2.2 then it becomes easier, but the
problem then is dealing with the shadow compression that
converting to the ICC causes.
#yiv1176463202 #yiv1176463202 --2015-03-19 by brian_downunda@...
2015-03-19 by Mike Johnston
Chart Throb works well too. Mike J. From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] Sent: Thursday, March 19, 2015 4:34 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re: Proofing paper for Eboni 6 on Epson 1400 and Arches Bright White Do you have the capacity to create ICC profiles for soft-proofing? This would require an i1 Photo or Colour Munki or similar. If you do then you can try a few things to see if you can soft-proof on other papers sufficiently well. If you don't then it's going to be hard. Perhaps someone here can recommend a cheaper uncoated paper. Not my area of interest TBH.
2015-03-20 by Brubaker family
I do have a Datacolor Print Fix Pro and the software, so I can create ICC profiles. Mike Brubaker -------------------------------------------- On Thu, 3/19/15, brian_downunda@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Date: Thursday, March 19, 2015, 6:33 PM
#yiv0631557957 #yiv0631557957 --
