Re: [Digital BW] Digest Number 7420
2014-01-23 by Yashasvi Bhuta
How does one print 640 gsm paper on inkjet I also have R3000. What settings are required. Also as to boost dmax use a very simple solution which I have empled over a couple of months. U need to add sizing to the arches paper with gelatine and fumed sillica nd hardening it wd formalin Using rd.95 coating rod or one may simply use a brush. If u want to add a little bit if tooth to the sheet consider adding 3% solution of dextrin white. Now I don't have a densitometric data to find out the exact figures but I do see a noticeable increase in dmax. And yes if considered for archival value . Gelatine is a time tested material and so is Fummed sillica. Sent from Yahoo Mail on Android
