Digital BW, The Print
Metallic paper card stock?
2013-12-06 by <roark.paul@...>
Red River Paper no longer appears to make my favorite metallic paper card stock. Does anyone know of an alternative source for card stock made from a similar metallic, glossy paper?
Paul
www.PaulRoark.com
Re: [Digital BW] Metallic paper card stock?
2013-12-07 by Ernst Dinkla
> Paul
> www.PaulRoark.com
The 300 grams version of RRs  metallic paper? Die cut to cards?  Never
seen both.
There is a Sihl 290 gsm 4840 MClass Metallic Pearl High Gloss Photo
paper. I can not compare it to the RR 300 gsm but the surface is close
to the ones described below, slightly more pearlescent, higher light
reflectance though.
The Red River Polar Pearl Metallic RC 255 gsm is the same as the Moab
Slickrock Metallic Pearl 260 gsm. The 5 grams difference should be ignored,
Met vriendelijke groet, Ernst Dinkla
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
December 2012: 500+ inkjet media paper white spectral plots.
