Digital BW, The Print
Canon IPF6300/8300
Canon IPF6300/8300
2013-06-08 by Larry
Has anyone had a Canon IPF6300/8300 or similar with a banding problem they could not resolve?
Our IPF6300 started banding about 6 months ago, we changed a head and it worked fine for a couple hundred prints over about 2 months, then it started banding again in the darker tones on both color and B&W prints. The banding is difficult to see and the printer always does a good nozzle print.
Canon Techs suggested changing the newer head again, which they supplied because it was still in parts warranty. It didnt help so they suggested replacing the second head which also did not help. Now after buying two heads and several hundred dollars in ink through numerous cleaning cycles and tests they say we need to schedule a $1000 service call.
Before doing that however, I see a couple of possible faults.
Canon told us it is not possible to print only one pure color at a time to determine which head or ink lines may be at fault as I initially thought that bubbles in lines may be causing some trouble. I now think that the circuit board components responsible for squirting ink through a particular set of holes may be defective and therefore looks like a head defect or perhaps the one of the feed mechanisms are binding or not keeping in sync with the ink squirting.
We have tried different settings, drivers etc and nothing helps so if anyone here has had a similar experience I would like to hear about it.
Re: [Digital BW] Canon IPF6300/8300
2013-06-08 by Ernst Dinkla
> Larry
Is there not a calibration feature in the Canon models and  should the
target printed not show the individual channels?
If not then the Bowhouse boys B&W RIP could do it I guess and it is
affordable + gives you B&W features that go beyond the Canon driver B&W
mode.
http://www.bowhaus.com/index.php4
Not using a Canon printer or TBW.
Met vriendelijke groet, Ernst Dinkla
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
December 2012: 500+ inkjet media paper white spectral plots.
2013-06-08 by photo692002
Thank you Ernst. I think that may allow printing of individual inks for testing. Since the printer also does color printing I need to keep the Canon ink in it. Bowhaus doesnt say on their site whose inks are used so that needs clarification.
Several years ago did you not use Canon large format printers?
Regards, Larry
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <e.dinkla@...> wrote:
> > Larry
> mode.
2013-06-08 by Terry Ritz
The Bowhaus RIP uses Canon's ink.
Terry.
> Regards, Larry
>>> Larry
>> mode.
> Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
> Please follow these basic guidelines:
> - As threads develop, trim off excess portions of earlier messages to keep them short.
> - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
> - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2013-06-08 by George Pappas
Hello Larry,
I feel your pain.  I had a Canon IPF5100 printer for 5 years and went through a very similar circumstance.  After swapping the heads, etc. and going through several diagnostic steps with Canon tech support, I was faced with the same decision you are now considering.
In the end, I decided to recycle the printer and purchase a new one; it it will help you, I will outline my reasons as they may be applicable to your situation:
1) As much as I loved the printer and the output it created, I had to realize that at 5 years, this may not be the last problem I would have and I could be in a state of continually throwing good money after bad.  The warranty that Canon would give you for the $1,000 service call would only apply to the issue that they fixed, not the entire printer.  I considered this to be some real on-going financial exposure.
2) After two heads (at $500 each) and another $1k, you could be buying a new printer with better technology.  Because the high-end printer market is limited, the manufacturers have a constant stream of incentives to purchase their new modes.  I was able to purchase a new Epson 4900 with rebates, etc. for only a couple of hundred dollars more that the heads/service call cost�..and have a new platform that will last me for another 5 years.  The prints are slightly better as well -though this was not the prime reason to switch.
3) I was able to sell the heads on Ebay at a reduced price that was good for me and the purchaser - I provided printer alignment checks and sealed the heads properly. I only had a couple of weeks' use on them.  You would need to check with Canon on the restrictions of using a head once it has been installed in your printer (left/right placement, model #, etc.)..I was also able to sell my unopened cartridges and printer stand�.
bottom line for me; these are complex devices still in their early stages of evolution.  You plan for the fact that the system could and will degrade - switching costs could be less than you think.
By the way, I used the bauhaus RIP for several years and it is an excellent product - I produced the best B&W output that software on the Canon Printer..
I wish you luck..
George
> Larry
George Pappas
george@...
2013-06-08 by tboleyyh
you may also be able to use StudioPrint in demo mode for this, you'd either have to print linearization charts directly and hope that shows you what you need to see, or create CMYKRGB postscript files with grads in each channel, or whatever illuminates the problem. CMYK Tiffs plus RGB alpha channels work also but are more complex to create..
True B&W may be more straightforward, I think it also has a limited demo mode, so no cost to test.
T
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Terry Ritz <t.ritz@...> wrote:
> Terry.
> > Regards, Larry
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <e.dinkla@> wrote:
> >>> Larry
> >> mode.
> > Yahoo! Groups Links
2013-06-08 by Larry
Thanks George, we are considering a replacement rather than sink another $1000 and several hundred more dollars in ink into this one with an unsure outcome in the long run. What hurts is it only has about 2 years of use on it, we got about 7-8 years out of our old 7600 before scrapping it for clogged heads.
Canon has a special this month for the newer model IPF6400 at $1800, was cheaper a couple of months ago but cant wait. Probably will go that route but what did you mean when you said you "sealed the heads properly" in order to sell/ship them? How did you seal them?
Can the ink cartridges be removed from the 6300 and reinserted in the 6400 without causing a problem? They use same cartridge and most of ours are about full?
Same question on our almost new heads, can they be reused without causing a problem if not allowed to dry out?
Regards, Larry
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, George Pappas <george@...> wrote:
> Hello Larry,
> 2) After two heads (at $500 each) and another $1k, you could be buying a new printer with better technology.  Because the high-end printer market is limited, the manufacturers have a constant stream of incentives to purchase their new modes.  I was able to purchase a new Epson 4900 with rebates, etc. for only a couple of hundred dollars more that the heads/service call cost…..and have a new platform that will last me for another 5 years.  The prints are slightly better as well -though this was not the prime reason to switch.
> 3) I was able to sell the heads on Ebay at a reduced price that was good for me and the purchaser - I provided printer alignment checks and sealed the heads properly. I only had a couple of weeks' use on them.  You would need to check with Canon on the restrictions of using a head once it has been installed in your printer (left/right placement, model #, etc.)..I was also able to sell my unopened cartridges and printer stand….
> I wish you luck..
> George
> > Larry
> George Pappas
> george@...
> Regards, Larry
No, I switched from Epsons to HP Zs, still are happy with them. A friend
switched from Epson to Canon so I did learn a thing or two.
The  Bowhaus RIP uses the Canon OEM inks. It looks like filling the
channels with monochrome inks etc is difficult so in that aspect it is
not like QTR + Epson printers where there are several choices of
alternative inks.
