Need help with Photoshop CS3
2012-11-24 by rfsteckmeyer
I'm trying to learn how to print B&W on an Epson 1430 using the E6 ink set. I'm running Windows 7 Ultimate and CS3. I believe I successfully made an icc profile using the excellent write up from Mr. Rorark and the QTR Eye-One program. Once I had the profile I on my desktop I renamed it QTR_1400_E6_EAM_NCC_2.2. I moved this to windows\system32\spool\drivers\color. I can find it in this directory as QTR 1400 E6 EAM NCC 2.2. Now the problem is when I try to find this file in the Photoshop menu (File-Print-Printer profile) it is not shown. Many other files in the directory stated above also are not found but some that are not in the directory are found. Is there a switch or something I need in Photoshop to see these files. Thanks for your help
