--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fvanoaks" <lfbgoldwork@...> wrote:
>... I've scanned the 21 step test wedge with the value scale ... entered the values in the linearization boxes ... I've tried it 0-100 and 100-0 but I always get the following message: Invalid linearize curve -- not constantly increasing. Curve Creation failed.
> Any help on where I'm going wrong at this step would be appreciated. Thanks.
You are not doing anything wrong per se; I had the same problem and was very frustrated because the values I entered were decreasing.
What I learned eventually is that even if your L-values are decreasing with each successively darker step in the wedge, the curve-fitting routine can fail. A more informative error message would be helpful and I have suggested this.
The present error message reads:
This leads the user to think the linearization values they have entered are not uniformly increasing or decreasing (depending upon if L-values or densitometry values were entered). However, after some searching one learns that even if the entered values are monotonic, the resulting linearization may not be monotonic depending upon how abruptly the entered values change and (I gather) what Gray Curve Shadow, Highlight, and (other values?) are selected by the user. It would help point the user in the right direction if the error message briefly stated something to this effect.
For example, the error message might read:
Despite decreasing or increasing linearization values
entered by the user, the calculated linearization curve
may not be constantly increasing. Check for abrupt
changes between entered linearization values or try
(lower or higher?) Curve Highlight or Shadow values.
You can review the values you entered and see if one or more steps show only a minimal change and try to average this small step with the next one so that the steps are more uniform. Another approach is to get better values entered in the first place. In my case, this was getting the values from a better quality (wider DMax capable) scanner. There is also a way to get values using your DSLR's built-in light meter for exposures. Perhaps that might work.
