Digital BW, The Print
UT-3D update?
UT-3D update?
2012-09-06 by MyronG
For a few years I happily used MIS's UT-3D in an Epson 2200.  It produced image tones that worked well for me, but most importantly, I could switch between matte and glossy surfaces without changing cartridges.
My 2200 bit the dust some time ago, and I am now using an Epson 4880.  The 4880 uses a great deal of ink when switching from matte black to photo black (because the ink has to be carried through tubes from stationary ink cartridges).   It would be *really* nice if there was a UT-3D way of enabling both matte and glossy printing.
I *assume* that I could use UT-3D inks in the 4880. Has anyone worked out the curves?
The real question:  Has Paul or anyone else developed any other ink set that allows matte/glossy switching via curves for the 4880?   It was never clean to me from the description of UT-3D how stable it was compared with other ink sets.
When I think about the 8 color printers like the 4880, I wonder whether it would be possible to replace one of the colors with the "other" black, and do a QTR version of ABW.  ...although perhaps the ink channels cannot be controlled that independently.
Myron
Re: UT-3D update?
Oops!   How embarrassing!  All the recent discussion of weak blacks on the Epson 4000 was in reference to the very kind of inkset I was asking about.
So:   Yes, Myron, there *is* a glossy-and-matte inkset other the  UT-3D that might work well with the 4880.
Re: [Digital BW] UT-3D update?
2012-09-06 by Paul Roark
Myron,
I'm sure the UT-3D approach would work in the 4880, but there are some
caveats.  First, I don't have any profiles for it.  Second, in K3 printers
I was not impressed with the Epson driver controls.  I think QTR is
necessary for good control in K3 printers.  The gray channel substitution
is too high for the Photoshop curves to have good control.  Third, I don't
recommend blended third party inks for wide format printers.
In terms of stability, I think the UT-3D would be about like other third
party B&W, blended inksets.
If you are proficient with QTR and want a variable tone inkset that can
print matte or glossy, consider
http://www.paulroark.com/BW-Info/4000-6K-Plus.pdf
Paul
www.PaulRoark.com
> the curves?
> other ink sets.
> Myron
