Digital BW, The Print
Multiple ICCs applied to one file by selection area?
2012-03-15 by Paul
Is there any method to apply one ICC to one part of an image file and another one to another part?
The usual workflow applies the ICC to the entire file.
I tried a software package that allows a print to file, but the resolution & quality is too low.
Any ideas?
The purpose is so that I can apply an ICC made with QTR's Create ICC-RGB to the main B&W image, but have the border printed with only yellow to control the bright paper borders.  Right now I'm using PS curves as the profiles, but it's a lot easier to use them if an ICC has linearized the profile (as opposed to me doing so manually).
Paul
www.PaulRoark.com
RE: [Digital BW] Multiple ICCs applied to one file by selection area?
2012-03-15 by E.Neilsen
I would use Q Image and add a border to the print using the software and not
try that ICC approach. Q Image is ONLY PC based answer. One might also try
it with LR. I haven't checked yet, but I am thiking adding a border is a
possibility there too.
Eric Neilsen
Eric Neilsen Photography
4101 Commerce Street, Suite 9
Dallas, TX 75226
www.ericneilsenphotography.com
skype me with ejprinter
Let's Talk Photography
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Paul
Sent: Thursday, March 15, 2012 12:21 PM
Subject: [Digital BW] Multiple ICCs applied to one file by selection area?
quality is too low.
Any ideas?
Paul
www.PaulRoark.com
Re: [Digital BW] Multiple ICCs applied to one file by selection area?
2012-03-15 by C D Tobie
If you use InDesign or another color managed page layout app, you can select different ICC profiles for different images. You would have to lay it out in ID, not import it as one image file, or the same profile would be applied to the entire image.
C. David Tobie
Global Product Technology Manager
Datacolor
5 Princess Road
Lawrenceville, NJ 08648, USA
609.924.2189
www.datacolor.com
Phone: 207.685.9248
Mobile: 207.312.0448
Fax: 207.685.4455
Email:  cdtobie@...
Skype: cdtobie
2012-03-15 by Seth Rossman
In PS.  Get your print ready, create your light yellow and "brush the
whole border on into the print area. Do it in one pass with a large
brush.  Outline the print area with the rectangular marquess tool
(easier if you bring guides to the very edes at 100-200% and set Snap to
Guides).  Use the history brush and wipe the whole area.  Only the part
inside the marquee will revert.
Second thought, it may be easier to "paint" it using Photo Filter if you
can get the color you want. then the marquee, history brush.
Third option, create a larger New File and tint it.  Then Copy and Paste
the B&W.
Seth
> Any ideas?
> ~-|**|PrettyHtmlEnd|**|-~ end group email -->
2012-03-15 by Ernst Dinkla
> Eric Neilsen
> Dallas, TX 75226
Qimage Ultimate allows colored borders, any color and any size. It also
allows different profiles or renderings per image with more images on
one print page and I think it is possible to shift one image over the
other manually on the print page but it would be a weird approach.
Met vriendelijke groeten,   Ernst
Shareware now:
Dinkla Gallery Canvas Wrap Actions for Photoshop
http://www.pigment-print.com/dinklacanvaswraps/index.htm
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
Re: Multiple ICCs applied to one file by selection area?
2012-03-15 by dlruckus
Hi Paul.It's a cluge but why not apply your print profile to an image copy then apply your border profile to another copy and combine copies via whatever selection method you choose. Then simply output the file direct to printer with no other color management eg: as you would for a profile chart or through a non color managed application.
I would think that using blend modes in Pshop could do this using  generic full sheet paper specific images while allowing full control of tonal placement.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <roark.paul@...> wrote:
> Any ideas?
> Thanks,
> Paul
> www.PaulRoark.com
2012-03-15 by Paul
It's easy to use a non-ICC method  to put borders on the images, but the ICCs make linearization of the PS curve profile much easier.  Thus I had hoped to find a way to use the ICC for the image and not the border. It turns out to be not so simple, at least with just Photoshop.
I too was thinking Qimage may be the answer, but I could not tell for their web page whether it would  work.
Ernst, you noted that
The problem is that the ICC for the B&W image is  not appropriate for the border.
> It also allows different profiles or renderings per image with
> more images on one print page
That was what I was hoping for.
The ICCs (made with QTR's Create ICC-RGB) work well for printing, but if I use Edit>convert to profile or Assign profile, that does not work.  So, how does Qimage apply the profile? Would it be in a way similar to the when Photoshop manages and  colors  in printing?
I thought I might need to have separate images and abut them, but it  is  a rather clunky workflow.
Paul
www.PaulRoark.com
2012-03-15 by Paul
That sounds like about the same  thing I was  assuming I'd  have to do in Qimage.  Again, I wonder if applying the ICC works like the PS printing workflow as opposed  to converting to that profile.
Paul
www.PaulRoark.com
2012-03-16 by Ernst Dinkla
> border.
I once discussed that with Mike, and it is correct that the border is
not getting the ICC treatment the image gets. Asked that I think in
relation with the gloss enhancer of the Z3100 and my method of giving
the RGB 255, 255, 255 areas in the picture a slight shift so they will
get GE too in the GE economy mode of the HP driver.
I can not try out a workflow to a custom B&W inkset on an Epson here. It
is also a pity that QTR does not exist as a nomal Windows printer driver
that I could use directly from Qimage, off-topic but my pet QTR topic :-)
More theoretically, if you can drive the custom B&W Epson printer with
the Epson driver, the last set on color and set on "Let application
control CM" or "CM-Off" and Qimage's CM-On and use the QTR created
ICC-RGB profiles there for individual images on the print page you
should get the same results as that workflow gives in Photoshop. On the
fly, no need to create a larger image with more images nested. It is
something I considered for printing different B&W toned images on one
print page with one customised B&W inkset. HP B9180 in mind with a small
gamut mix or the inkset that comes close like the one you developed last
month.
PS can not have more than one image on the printpage at that stage, it
could prepare a page like that but then you would need to do some P2P
conversions with the QTR profiles and assemble an image+border (or is it
possible to do P2P on selected areas, reverse the selection in between
the two profiles?) and then assign a profile to the image that will go
through a print CM path that does not alter the numbers anymore (so no
CM in effect after the P2Ps). If selected areas + P2P works, you could
make an action like that, for example cannibalise the plain canvas wrap
from my set of canvas wraps and add P2P steps on reversed selections and
assign the color space for the CM-Off path. On Macs the last needs more
attention.
I can try out the overlay of images in Qimage, I did see that effect
when I once misused print page nesting for lay-out work. There is also
the "Print to File" feature in Qimage that allows the use of printer
profiles in that step and you can judge what is altered in the RGB
numbers of the resulting Tiff. Better feed a neutral RGB image then.
Qimage does not know a Greyscale image, it converts Greyscale to RGB
right away and what it sends to the driver will always be an RGB bitmap.
Well you always surprised me with mind boggling methods and they did work.
Shareware now:
|                 ( unvollendet )                 |
> attention.
One minute in PS and I would not have written that part.
Curves could do the job though.
P2Ps and stacking images too.
Shareware now:
|                 ( unvollendet )                 |
> month.
In Qimage Ultimate I can put two images on one print page (make sure
both have enough space to fit on that print page), lay the last loaded
on top of the other and give them different ICC printer profiles
including QTR ones and print the total. That worked at least in Print to
File mode but I do not see why it wouldn't in a normal print job.
Practical issue may be that you need a larger print page to load the
images but like to have a smaller one for the print.
For practice I would think it is easier to check with Print to File what
a QTR RGB profile does to a certain color in Qimage and select a Qimage
border color with the same RGB values.
met vriendelijke groeten, Ernst
Try: http://groups.yahoo.com/group/Wide_Inkjet_Printers/
