Re: [Digital BW] Digest Number 6591
2011-04-10 by Myron Gochnauer
With a 3880 I can just switch cartridges as Gary suggests, but with the 4880 the process involves removing the cartridges on the left hand side of the printer, inserting "conversion cartridges", draining the ink, and then replacing the conversion cartridges with ink cartridges (including the new version of black). Since I did not open the "conversion kit", I don't know what the conversion cartridges are like. They may be small, empty cartridges, so that the draining process does not draw new fluid into the reservoirs. Does anyone know? Myron On 2011-04-10, at 7:17 AM, DigitalBlackandWhiteThePrint@yahoogroups.com wrote: > I own an Epson 4880, which I have used only with MK ink. > > I would like to switch to PK black ink, but cannot find the black-ink-switching-kit that came with the printer. > > I haven't been able to find it on the Epson site either. Is it there? Where? Is there any other source for a replacement? > > 1b. > "black-ink-switching-kit" A black ink switch?. When you want to change from MK to PK don't you just remove the MK cart and insert the PK cart and let the > printer go through its initialization process which will use quite a bit of ink. > > Gary [Non-text portions of this message have been removed]
