Korg DW8000, Mono/Poly, MS-20...
Archive for DW8000.
Ref DW-8000 problem
Ref DW-8000 problem
2009-02-15 by inspectorpenny
I just received a DW-8000 from a friend who had not used it for years.
It seems that certain patches have a intermittent static sound that
cycles about every 5-10 seconds. I'm guessing it's a certain
parameter change which makes it more or less prominent-depending on the
patch. Some patches are not affected at all. It only lasts a split
second but can be annoying. Any thoughts
would help greatly.
Re: Ref DW-8000 problem
2009-02-21 by resistenzaaoltranza
> would help greatly.
In my humble opinion ( I am not a technician at all..) it could be
useful to reload all the original patches using the cassette data
interface, or simply the midi port,there are some programs You can
use. If the patches on Your Korg are customized ones, and You like
them, just save them using a PC program, and then reload the original
ones. If everything is wrong again, I would suggest You to change the
internal patches backup memory battery, maybe is too old to work
correctly. Then, try to reload the original patches, and hope......If
it still doesn't work properly, here is surely someone more skilled
and professional than me who surely can help You!
Cheers, Francesco.
